Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 150 Guests are viewing this topic.
sm0ky2
Quote from: synchro1 on February 24, 2018, 03:25:23 PM
@smOky2,
What's the definition of a Henry of Inductance?
When you store and release a magnetic field in an inductor
it is the inductors tendency to resist a change in current.
It can also be defined by flux/current for each unit time
Or
Kg m^2/s^2A^2
For this value to be (-) means you have an inversion of
electromotive force (I.e. reverse current)
synchro1
Quote from: sm0ky2 on February 24, 2018, 05:23:10 PM
Or
Kg m^2/s^2A^2
@smOky2, Citfta,
I built a copper wire coil with a variable ferrite core I showed in a video above. I positioned the core in the coil to measure zero inductance with my inductance meter. When I move the ferrite core out one centimeter, the inductance measures negative .001 mH. When I move it out two centimeters, it reads negative .002 mH. Now when I reset it to read zero, then move it in one centimeter it reads positive .001 mH and when I move it in again another centimeter it reads positive .002 mH.
Now are you two maintaining that the negative reading has no value over the positive one as a core locator?
sm0ky2
About the quote:
I would have to see that in full context to know what is being said.
Your coil, when the core is inserted forms an
inductive rheostat, or variable inductor
sm0ky2
If you don't have another set of clip leads
You can make leads from copper wire to take a reading
synchro1
Quote from: sm0ky2 on February 24, 2018, 06:13:48 PM
@smOky2,
Why should I do a stupid job like that for you?
