Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 171 Guests are viewing this topic.
synchro1
"The force of the lock is proportional to the square of the relative permeability of the magnetic core. Given the relative permeability of a material can vary from around 250 for cobalt to around 5000 for soft iron and 7000 for silicon iron, the choice of magnetic core can therefore have an important impact upon the strength of a magnetic lock. Also relevant is the choice of current, number of loops and effective length of the electromagnet".
This basic law underscores the central point I've been making the entire time on this thread. This augments "Faraday's Law". The magnetic force of an electromagnet is proportional not only to current and number of loops, but more importantly "The square of the relative permeability of the core". The converse of the law, which you will never see published anywhere, is that the output of an electromagnet coil is a direct function of the core perm too!
The COP of a "Chiral Siamese" electromagnet MEG would be a function of the relative core permeability of the two electromagnets!
Therefore: Doubling the core perm in a twin facing EM MEG will quadruple the COP!
My oscillator tests prove conclusively that the power in, to the force field out is equal to the force field in to the power out in the electromagnet.
synchro1
The standard unit of inductance is the henry. The equation for calculating the number of henries in an inductor is:
H = (4 * Pi * #Turns * #Turns * coil Area * mu) / (coil Length * 10,000,000)
The area and length of the coil are in meters. The term mu is the permeability of the core. Air has a permeability of 1, while steel might have a permeability of 2,000.
synchro1
The magnetic fields are interpenetrating along the "A" vector at 180 degrees in the oscillator, neutralizing "Lenz Drag", like the zero force motor does by positioning the output coil at 90 degrees.
This helps explain why we witness an even exchange. Using a magnetic core with a spinning rotor magnet is self defeating.
synchro1
Look at this 10 Henry choke and the silicon steel laminations:
