Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 164 Guests are viewing this topic.
synchro1
Following Gotoluc's formula for his 'Self running coil" I next need to induce "One negative Henry" of permanent field inductance into the 2 Henry "E" core by attaching a sufficient number of permanent Neo magnets to the core.
This should be enough to generate the same oscillating power from within the coil that Gotoluc demonstrated in his series of 16 videos. I carried a case filled with the most powerful Neo magnets available on the open market from California to Costa Rica last September. Now I'm ready to try attaching them to the inductor core.
__________________
synchro1
I started measuring the heat from the 2 Henry oscillator while running with the infrared thermometer, and it's measuring a drop in temperature. This is the opposite from what I anticipated and opens a whole new area of speculation. Maybe it's simply the cooling effect of the flipper fanning the coil?
synchro1
synchro1
Here are 100 millihenries of negative inductance in magnetic field strength from two powerful 3" Neo disc magnets. Quote from above:
"The 10 Henry choke, which measured 10 Henries when I first got it, now measures 1.91 Henries with the core split".
synchro1
Quote from: synchro1 on June 29, 2018, 12:04:17 PM
