Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
I added two neo disc magnets to the stator and wrapped two elastic bands around the rear Piezo and generated a steady 120 volts. Next I'll try and light he flouresents.
https://youtu.be/rIpsn_eZ2rY
synchro1
On Piezo output from vibration:
"Depends on type of mechanical 'excitation' used. If persistent value force is used, a constant DC voltage source is generated".
The 120 volts is D.C.
synchro1
        PI/PO
Working the 500 Newton (100) lbs. of force electro-magnet with doubled over elastic bands and Neo disc magnets increases the vibration force but also eats up a lot of power from the wall socket.
Simply attaching the piezo chip to the upper back end of the vibrating stator comfortably generates around 3.5 A.C. volts. The piezo generator requires a diode and capacitor to rectify and store an increased charge that can illuminate perhaps a bank of 3 volt LED's. This would match the voltage from the BEMF.
