Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
                                                           Analysis
Forcefully "Whipping" the piezo transducer on the tail end of the oscillating steel rocker generates high D.C. voltage.
Imparting a "rippling wave action" at the resonant frequency of the chip generates an extrodinary amount of voltage (+200).
There's over 100 pounds of attraction force exerting torsion on the piezo chip in that fluttering position. We may not find a better output approach.
synchro1
                                                             30 LED's 1 Piezo chip
Look at the illumination strength this tester is generating by just pinching the chip between his fingers! The fluttering transducer should light 100.
https://www.youtube.com/watch?v=-qmg0WvSXSI
synchro1
How do the magnets in attraction attached to this electro-magnet and stator effect the flyback? When the current is interpreted, the magnetic field in the electro magnet coil collapses from the outside in. That's the same direction the converging permanent magnet fields in attraction travel when they reconverge.
https://apis.mail.yahoo.com/ws/v3/mailboxes/@.id==VjN-1X9NaLC9ZX3FaL6CGMuswusjkt9d1-tx3R3qM3BRpHb3fu55JdZSfkPWvGRe0gruGl2LEeEb8L4Fd0GBJs5fOA/messages/@.id==AMLtTXY0EYQlXBdpbwwN8PEJGBE/content/parts/@.id==2/thumbnail?appId=YMailNorrin&downloadWhenThumbnailFails=true&pid=2
synchro1
        Double implosion
The regauging permanent magnetic field is pressed right up against the collapsing magnetic field in the coil that opposed it after the current is interrupted. The output is A.C., primarily because the re-penetrating field is an opposite polarity of equal force. Both events transpire within the tiny time frame that the contact points are connected, shorting the coil through the SPDT spring pressure.
This oscillator does the job of inverting input like a Ruhmkorff Coil without the secondary!
