Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
                                                      Microwave oven door switch
Quick and dirty "H" bridge:
Coil ends would connect to the common pins of each of two switches. The NO and NC pins should connect to their matching pins on the other switch by wires with stripped sections in the middle for the power: Negative to NC and positive to NO.
https://dl-mail.ymail.com/ws/download/mailboxes/@.id==VjN-1X9NaLC9ZX3FaL6CGMuswusjkt9d1-tx3R3qM3BRpHb3fu55JdZSfkPWvGRe0gruGl2LEeEb8L4Fd0GBJs5fOA/messages/@.id==AGL50y05czFAXLxn0wVi6DmhW1A/content/parts/@.id==2.2/raw?appid=YMailNorrin&ymreqid=3365852a-c14e-b304-1c47-c40001013f00&token=zitEzqOML3j84e6ealFTT5U7-km5qEQF52lp7AcCuBYuSfoFz8vQYu01Ebe_f8pg2ITMlv4-3AvnkLQDemZLxHwtsH6_HC8hR_TqMSR7KK7Kq2x236OSj64rSSjwoc6v
synchro1
                                                            Reverse direction
I noticed the monopole driver will move in the wrong direction from the same pulse if it's offset inside the coil core. The "Adams" kick needs to be looked at on an oscilloscope to see what's really going on and how best to synchronize these magnetic field shifts.
Running the "H" bridge monopole in Adams resonace and looping the flyback should deliver an OU COP. Timing the backspike to add power amounts to "Lenz Propulsion".
synchro1
The separated wave form below shows where we would position the monopole magnet on the ferrite oscillator driver to benefit from "Lenz Propulsion". The SPDT switch would be positioned to trigger exactly there. The magnet on the other end would be in the center of the coil awaiting the pulse; Centered so it would attract on one side and repel on the other.
synchro1
microwave door switch. wedged in pvc t with a chopstick.[/size]
