Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
@kolbacict,
Thank you for the addition: Nice component!
This may be the first time anyone has ever explained how Lester's generator really worked:
Hendershot combined a horseshoe magnet with 2 electro magnets and a stator. He reduced the power to 1 electro-magnet and a spontaneous vibration appeared from the field asymmetry. He tuned for the "Neutral Zone". I accomplish this same effect with the eccentric positioning of the permanent magnets. A nuclear force is powering this oscillation as the electron domains shift their polarity at a regular frequency. We are actually harnessing atomic energy.
synchro1
Hendershot used a "U" core with 2 coils. I use a pot core with 1 coil. The Microwave is a 1 coil core with a split field like the electromagnet. Positioning magnets asymmetrically on the Microwave "E" core with 2  straddling the center leg and 2 on one end, in opposition polarity would generate a substantial mechanical motion in a spring blade with magnets attached to perhaps power something large. A "AA" battery may be enough to maintain the electromagnet field enough to oscillate a large spring blade and magnets.
kolbacict
I don't understand anything ... Why can't you replace your electromagnet with a permanent one?
synchro1
Quote from: kolbacict on March 20, 2020, 10:25:16 AM
The electromagnet field and the permanent magnet field are qualitatively different. Gadolinium will attract to a Permanent Magnet field but not to an electromagnetic one.
The interaction of these dissimilarities feed the oscillation.
synchro1
Quote from: synchro1 on March 20, 2020, 11:13:11 AM
The microwave transformer should oscillate a carving knife blade with a stack of 1" inch neo disc's attached. The oscillation will immediately start charging the run battery. A separate output coil can pick current up from the disc stack.
