Ambient Energy
Started by cliff33, November 27, 2017, 06:44:43 PM
cliff33
Welcome to the "Ambient Energy Thread"
I have read hundreds of postings on free energy in which everything is discussed except
the very basics at hand. I guess some people only want to impress others with their
fanciful irrelavent theories.
  I hope to correct this problem by discussing only the basics needed to acquire this energy.
All that's required is some basic electronic theory and lots of common sense.
By reading much of Tesla's experiments, we already know that our earth is sitting in a sea of
energy that most people are not simply aware of.
  For lack of a better word Tesla simply called it "aether waves".
He said the aether through out the universe consists of sub-atomic particles of matter
that have either a positive charge or a negative charge. Particles so small that they can
travel through anything.
  Luckily mother nature assures that everything stays in balance by providing as many positive
charges as there is negative ones.
  Sometimes however, an area in the upper atmosphere accumulates more positive charges then there are negative.
This unbalancing creates a state of tension for the positive charges
which are just itching to meet up with all those negative charges surrounding our earth.
But they can't get down to earth because the dry air acts as an electrical insulator.
So they remain in limbo until mother nature creates a rain storm which then moistens the air
enough for them to travel downward. They reach the earth with a big bang that creates
billions of watts of electricity.
Thanks go to mother nature for putting things back into balance.
All this is to show that there IS electricity in the air. We just need a way to access it.
More to come.
cliff33
It's been said many times, that to access this energy from the environment we need to first
create some kind of disturbance to create an imbalance.
This disturbance wakes up some of these charges which then tend to move into the path of our
HV coils.
Of course the higher the voltage, the stronger the disturbance which attracts MORE charges.
The more often we can get this to happen (frequency), the more charges that will accumulate
in our circuit.
A spark gap that just acts as a H.V. switch is of course the most practical way of creating this disturbance.
When the coil voltage is building up to the point where it peaks on the sine wave, then a
spark will occur across the gap. If the HV rectifier anode is connected to the top end of coil
and cathode connected to the spark gap, then from the S.G. a positive going pulse will be
going through the main H.v. coil then back to ground.
  When sine wave drops in strength, killing the spark then the coil's magnetic field suddenly
collapses and gives off a much higher going negative pulse.
It is this much higher pulse that we should use to attract the charges into our circuit.
As we all know that the earth has far more negative charges than positive then we should be
striving to attract more positive charges from the ambient surroundings.
Since only opposites attract, then the main HV coil should be pulsed using the stronger
negative pulse to  attract more of the positive charges. The positive going charges will then
be attracted to the negative earth ground by first passing through our main HV coil.
This all will require the use of a second H.v. rectifier connected in reverse to capture
those negative pulses.
  If the HV coil puts out 6kv then we only have to attract 1/2 amp into our circuit to get a
power out of 3000 watts. 8kv = 4000 watts.
Moral of the store:
Use lots of high voltage. And use very high frequencies (mhz).
forest
Moral of the story : read more Tesla notes.
mxcarlosdigit
Hi Guys,
Just wondering:
What about using AI to create/help define a perpetual machine. There's lot of information out there fake an real, We have Tesla and others patents, physics, mechanics, new and crazy theories, new materials, etc. Why not get help from a system that could analyse all that data Just to put it to a test
check out following video to feed your your imagination
https://www.youtube.com/watch?v=aR5N2Jl8k14
First and last post
cliff33
Ok, now let's see if we can make some of that high-voltage and very high frequency voltage.
We can follow the example of a Tesla coil by using many turns in the secondary and pulsing the base with just a few turns.
  Don't use a large diameter coil for this, as we want a slim coil form that can take a few hundred turns. The more turns in a coil, the higher the voltage.
The best coil for our purpose would be a 1/4 wave-length of fine wire wound on a 1 inch form.
If using 3mhz for our resonant pulsing then 1/4 wl would be approx. 247/3 = 82ft. or 984 in.
If using #28awg wire which has 72.7 turns to the inch then one turn would be 3.14 x 1 = 3.14 inches. Wire len.(984) divided by 3.14 = 313 turns. Coil len. would be 984/72.7 = 4.3 in.
So a 6 in. core len. would do just fine.
I know there are some out there (I was one of them) that will tell you that you can't get resonance by winding a 1/4 wl piece of wire into a coil. Don't believe them.
  A coil like this with many turns has capacitance between the turns which also makes it
resonate at a much lower frequency. This is the LC resonant frequency. Don't use it.
The 1/4 wl coil seems to just ignore all the built-in capacitance.
Using just 10 watts of input power, I can pulse one of these coils with a 2 turn link at the base and get over 6kv at the top end.
Kapanadze mentioned that he was using "automatic" resonance for his coils. So maybe it's this type of coil he's referring to.
  That's it for the voltage generating coil. Will get into the main H.V. coil next time around.
