The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
sm0ky2
Now that we have a clear image of how the Diameter affects the force
Due to the magnitude of charge held in capacitance.
Let us move on to how the Mass of the moving object affects things.
If capacitance can be maintained, while reducing the mass of the
moving conductor, more force can be siphoned out in the form of
electrical energy.
For example, a hollow sphere of the same diameter.
Less mass means greater acceleration imparted by the same force.
Because F = ma
If m goes down, a goes up.
The inductive constant presented by Ampere's Law, is the mathematical
synonym for the effects caused by mass.
The anti-force imparted by the coil onto the moving magnet
Has the same effect on the moving conductor that mass has on it.
The greater the inductance, the lower the acceleration.
This is defined by the magnetic portion of the Lorentz Force equation.
We can set this value to the acceleration caused by the charge force
and find the inductive equivalent to the inertial mass function.
This defines the quantity of energy, over time and distance,
That can be extracted from the charge force, by lowering the conductor's
mass by a given value. (assuming the mass was originally at maximum for the device)
I'll sort of re-cap that to make it simple:
The charge can move up to a certain mass
If we lower that mass, the charge moves it faster
If we slow the smaller mass down to the same speed
that the larger mass moves at (by extracting energy from it)
The charge force is not changed.
We therefore can take freely the difference in energy.
Without changing the input and output of the electrical energy
Per cycle.
sm0ky2
We see here,
that total input and total output hold an inversely proportional relationship
As output increases, input decreases.
This stops at the point where we extract so much energy, that the conductor
can no longer move. Resulting in no charge/discharge, no input and no output.
So we take a value of energy slightly less than this, and we result in maximum output
and minimum input. (Low frequency discharge).
In this condition we are extracting the maximum value of energy from the charge force.
In the theoretical ideal condition of a massless conductor, with infinite magnetic strength
We could extract infinite energy from relatively finite charges.
But our conductors have mass and our magnets have even more mass
So these are our current limitations
Grumage
Hi sm0ky2.
I set up one of the 150 mm/6" spheres using a thread suspended from the ceiling. After a few seconds the sphere became a " wrecking ball " !! This was acting between the Van De Graaff generator collector and another 6" sphere held by me acting as ground.
If I was to fix the sphere to an insulated rigid tube and the other end was attached to a " sprag clutch bearing " I could effectively turn the violent to and fro movement into rotation. With gearing this might have enough energy to drive a reaction machine to provide the supply??
I'm pretty sure there's other ways to do this too.
Cheers Graham.
PS.    https://www.youtube.com/watch?v=u53Vwodew_Y
Void
Nice job Grum and TK!
All the best...
