Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
wattsup
Quote from: Void on January 11, 2018, 01:38:10 AM
@Wattsup amd Hoppy:
You guys are funny. Wattsup refers to Hoppy as 'Happy' and
Hoppy refers to Wattsup as 'Wottsup'. ;D
P.S. @Everyone: Speculation is not fact. It might be true, but it might be completely false. :)
Coils might be decoys, but they might just as well be essential too. The only way to know if something
works or not is to see if it is working in a test circuit. Bottom line. You can't be sure about anything with these
circuits unless you can prove it with a working test circuit, or unless Kapanadze has a change of heart and
gives specific details about what is going on in his devices and people can get that to actually work as well.   ;)
Brainstorming is good, but I see a lot of apparent speculation being expressed as if it is demonstrated facts. :)
All the best...
Yep, you are so right. I always saw his username as @Happy. Sorry about that @Hoppy. I'll remove the smile and replace it with a jumping jack. hahaha. Also Wattsup has no capital W.
I don't think anyone here is insinuating any facts but you have to agree this is far more then speculation. Speculation is when you have nothing of substance to base it on. What we are doing is more of an inventory of possibilities based on possible known and some unknown effects. Unless TK hid the real OU somewhere inside the TK coil, that coil has nothing conducive to mass coupling hence it could be a one pass concentration point for HV chopping. Sorry I don't have a better word for it.
Since HV chop is something I have never done or heard of, so for me it's new, so I will make plans to try it on the bench. It does not have to be to scale to see if the basic idea is workable so any HV coil will do. I imagine PNP will be required so no problem, I have many. I also have a permanent true ground cable coming into my lab to simulate the underground radiator. The bulbs only need to be in series with the ground and the chopped HV output.
wattsup
kpannic
I think the ideea is mix low voltage and high amp with high voltage and low amp. The orange wire already have high amps and add voltage from high voltage. Everything is like mixing oil with water .. we need a tool to do that, kapanadze discovery that tool.
***** Tariel said, the device is very simple ****** let's start from here.
Belfior
I think the solution is so simple that it made TK add all kinds of smoke and mirrors to his device. You only add extra crap if the solution would be obvious otherwise.
Like how does the secondary coil in a transformer know what produced the flux? No electrons pass the transformer coils to each other. So what if I use HV on the primary and pull out 230V from the secondary? Where does the need for amps come from?
Or if I charge a cap 35000 times per second with 5kV , feed that through a spark gap into a primary and then take 230V AC out of the secondary. Does the load on the secondary magically pull amps from my 5kV device or does it pull it from the magnetic flux on the transformer core?
AlienGrey
Hoppy I thought it was from that clip in south Pacific 'Hoppy talk' nice clip if you can find it.
To live some where like that miles from the rest of humanity sop called civilization would certainly be different.
kpannic
a few moments ago I  destroy an 220v / 12v1A adapter, but I can not figure out how I did it. The connection between the spark and circuit it was isolated by the optocoupler and toroid transformer (see diagram below). The oscillating circuit and the mosfet are not damaging. WHAT HAPPENED?
A small explosion occurred in the adapter that fed the oscillating cycle when I was playing with the frequency of the oscillator. I think it was a fraction of a second I see yellow flash that does not know where it came from. (from the bulb?). Inside of the adapter I found pieces of an integrated circuit.
