Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Void
Quote from: forest on January 13, 2018, 02:04:51 PM
Maybe Barbosa and Leal was the real danger to electric companies but Kapanadze was already ridiculed and controlled ?
Hi forest. I am not aware of Barbosa and Leal having ever demonstrated anything like Kapanadze,
very up close in front of other witnesses, with no connection to the grid and showing an apparent self runner.
If you look at their patent drawings, when they are connected to the grid the power will obviously be coming
from the grid through the ground loop. The only person I know who claimed to see a Barbosa and Leal device
working using a battery and inverter was Fernando, but his account is quite questionable to me. There is not
good reason to think that Barobosa and Leal's devices might be over unity, but for me Kapanadze's self running demos
are much harder to criticize as so far I have never come across any credible evidence that Kapanadze is using tricks.
Really it is a very big difference between someone showing something connected to the grid and claiming OU, and
someone showing an apparent self runner right up close in front of other people and allowing them to inspect wires
closely, etc.
All the best...
cheappower2012
Everybody keeps forgetting its not an ordinary inverter ,Kapanadze is using.
The noise heard is a transformer being overloaded,one operating at 50Hz,however the inverter used by Kapanadze appears to me to be one that is a switching transformer type,transformerless,It operates at a high frequency,changing the low voltage dc to over 220 vdc then a series of mosfets are turned on at 50 Hz to create 220 v ac,50 hz.This inverter is not a type encountered in the US,it appears to have a low wattage transformer also,1:1 it outputs 220 vac 50 hz from the main supply,however it can not source a great amount of current,possibly 100 watts or less.Kapanadze's device needs greater than 100 watts to work so the transformer is over loaded,this is where the noise comes from.When he unplugs it from the mains,it switches to the switching
power inverter automatically,which can output (400 watts I believe) more than it needs to run the device so the noise stops.This inverter is not your usual type at least not in the US.It maybe used in a kind of
back up,where a device is hooked to the output and powered by the mains,if theres a mains power failure it switches to the battery operated inverter part automatically.
To void
The main point is the device has an oscillator at 50 Hz,when the power is cut,it increases in frequency,most oscillators are fairly stable with voltage decreases ,they will work  a certain amount of time until the power supply capacitor's voltage drops enough then stop working, not change frequency.Only one circuit does this a blocking oscillator circuit ,the frequency will increase with a drop in supply voltage.In the video you can trace the orange coil,kapanadze tried to make it appear like two coils it is one,so you have a
problem,is the high current coming out of the tin box or is it created in the coil? You can approach the device simply using tools
gotten by knowing electronics, however, for it to be real it has to operate in a completely different way,its not a Tesla invention nor related to anything Tesla.In my opinion Kapandze doesn't fully understand how hes device works,only how to assemble it to make it work,this indicates to me it was an accidental discovery
,hes builds are different each time to throw off anyone trying to figuring out how to build it.If he doesn't tell you how to construct it,you can never figure out the theory behind it.
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
PolaczekCebulaczek
Oh another Kapanadze  topic.
so here is my theory:
Kapanadze told us three things:
1.Simple as you would laugh
2.He find a method of auto resonance.
3.Some sort of tesla coil that takes energy from space.
well, if we can take kapanadze words as truth then this idea comes to mind:
it is possible to design a tesla coil resonator in such a way that it will always resonate at maximum efficiency no matter how big or small the capacitance is? if so than what would happened if we change capacitance value very fast for such circuit? (using spark gap to give or take electrons from some metal?) kapanadze was using coax cable for his older devices, this cable can be used as capacitor and inductor.This is a good start http://www.linux-host.org/energy/sgenesis.htm
