Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Void
Quote from: SolarLab on January 15, 2018, 11:46:10 AM
A revised link with the "Chart 9" (picture) is here:
http://freenrg.info/Misc/Genesis/
It's interesting. Regarding 'The Genesis Project', does anyone know who wrote the document
and who built the devices shown in the document? Who were those people and where are they now?
From the pictures in the document it is hard to tell whether there is anything unusual going on there
or not as they provided no details about input power and output power, and really no details at all
about how it was being powered.
Throwing around ideas and speculation can only take you so far (which is usually not very far at all when
it comes to the topic of OU), but has anyone built any test circuits which they think actually show some
interesting or promising results based on their ideas? That's what really matters IMO.  :)
If a person can't back up what they are suggesting with at least some sort of basic test setup, then what
have they really got? Just words... ;)
All the best...
Hoppy
Quote from: AlienGrey on January 15, 2018, 06:46:15 AM
Have a look at this circuit !
For me many ideas spring to mind with this circuit 'it's' just an idea with many problems to iron out!
The driver stage if left as is will draw loads of DC and the base driver circuit might need modification
in it's bias circuit and the output stage might also need some attention or modifying.
However the output drive is modulated carrier wave drive, say no more play with it as you wish but if you find anything please report back so we can all benefit from it !
Interesting cct Alien. Looks simple enough to be a contender for TK's devices. His green 3-phase trafo looks like it could fit in place of TP2. Have you built it yet?
Zeitmaschine
PolaczekCebulaczek: »3.Some sort of tesla coil that takes energy from space.«
Kapanadze never mentioned a Tesla coil. He said, he used Tesla's schematics, because Tesla invented this. So, who is willing to search for a Tesla patent, that shows a frequency doubler circuit?
Void: »If a person can't back up what they are suggesting with at least some sort of basic test setup, then what
have they really got? Just words...«
And a lot of saved money instead of non-working stuff due to having no idea whats going on in the setup. First switch on the brain then the transformers.
core
Quote from: Zeitmaschine on January 15, 2018, 06:20:15 AM
core: »So look at the problem from a different direction, because in the last 7 years basically every type of coil configuration has been used.«
Can't remember seeing the below configuration yet.
I understand where you are going, but are you really convinced there is one magical coil combination that is the secret? On the most basic level in order to provide more energy you need a fuel source, that should be no mystery. What are you guessing is the fuel source? An analogy would be a cutting torch, acetylene will ignite and burn but this with no air is very inefficient. Add a catalyst such as O2 and the heat output is magnified exponentially. All these devices have an additional fuel source that could easily be manipulated or controlled with a magnetic field.
Who knows what this fuel source is maybe ions, mixture of metals, some type of radio active compound? then something needs to react with that fuel source. Barbosa and Leal have 2 devices that achieve the same result, one (1) from the air and one (1) from the ground. That said, we then know that GROUND is not a requirement. So what fuel source do they use that allows them to supply more power to the output with two different devices? Is there a compound being used? does there core material draw more power? or is it just a hoax.
-Core
core
Quote from: Void on January 15, 2018, 12:55:38 PM
But that is exactly what these forums are! These forums are not team sites or even build sites, they are places you go to and share ideas. These are the places you go to and share your words. There are better avenues out there to share work/builds.
-Core
