Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Quote from: sm0ky2 on January 16, 2018, 10:35:59 PM
Don't confuse high voltage/low current with low energy.
High voltage can create heat a lot faster than high current.
and more efficiently.
Ionization Energy and Melting Point are tied to the same
nucleic factor.
Feel free to demonstrate the truth of your assertions.
Of course high energy is transmitted over high-voltage, lower current transmission lines in national electric supply grids constantly, due to reduced losses from joule heating which happens with low-voltage high current systems.
Quote from: Void on January 16, 2018, 01:59:47 PM
Hi TK. Are you saying that you have achieved over unity with your device?
No, of course not. In fact I have not even built the full EEEE system (yet) due to lack of space (ironic isn't it) and funds.
If not, what are you suggesting?
I am "suggesting" that the devices I have designed, demonstrated, proposed and explained perform all of the things which others have suggested as the "secrets" of overunity. People are flailing around without any coherent scientific theory or well-formed testable hypotheses, not to mention the chasing of hoaxes that will never result in any payoff but will simply waste the time, energy and money of well-intentioned, hopeful, but naive experimenters (if they can be called "experimenters" at all rather than simply misguided hobbyists.)
As I noted above, the apparatus does everything listed by another poster, does it simply and cheaply and compactly and most of all, scientifically. There are sound scientific principles that hint at extremely powerful energy in the vacuum, and it is my intuition or tentative belief that the way to get to this energy and make it useful is to create stresses in the vacuum which will cause pair-production, and then an established power transmission system may then be able to entrain some -- perhaps an infinitesimal amount but still significant -- of this released energy of the vacuum -- AKA the real ZPE -- into a pre-existing flow of power, which thereby may be increased. This does not violate CoE or other "laws" of thermodynamics.
The apparatus I have outlined is a table-top demonstrator of these principles. I've stated elsewhere that stressing the vacuum to the needed degree will probably involve electric field strengths an order of magnitude or more greater than the simple demonstrator can achieve, and that "success" may be manifested, at first, as reduced losses resulting in a _slight_ increase of output power, or an improved ratio of out/in power.
What you show in your video doesn't appear to show anything out of the ordinary
beyond normal 'wireless' induction between some tesla coils.
All the best...
My video (and others in the same series, as well as Gotoluc's work with the apparatus) demonstrates several simple parts of the idea: the power flow through space, capacitive stress, and the stepping-down of the transmitted HV/Low current into low voltage high current. The power flows through space in the TKoil X system mostly not by induction, but by capacitive coupling. The apparatus I've outlined called the "EEEE" overlaps inductive magnetic coupling and capacitive coupling and demonstrates the stressing of the vacuum due to the strongly coupled electric fields (capacitive) along with enveloping magnetic fields (inductive) . This is identical to what people have been flailing about with such things as "coil-capacitors" and so forth. Only it works. It is my firmly held and scientifically supported opinion that the devices mentioned in the title of this thread are mere hoaxes and red herrings... but as I have often said the best red herrings are real fish. By this I mean that the Kapa, Stepanov, Akula etc devices do work, for certain values of "work". That is, they are good _receivers_ of transmitted power using mainly inductive coupling, but they fail to create the proper conditions of stressing the vacuum in order to entrain "new" energy to make their outputs increase to the point of "overunity" performance. They are in fact receiving their power (all of it) from ordinary sources not shown by the hoaxers, and this is why the "replicators" here have not and will not ever succeed in their goals of making "self runners".
(The Barbosa-Leal devices are simply working from their local SWGR grid system, as has been explained many times over.)
AlienGrey
Quote from: Zeitmaschine on January 16, 2018, 05:30:16 PM
Void: »you can connect a section of metal pipe such as iron (has more resistance than copper) as part of the high current loop and it will get very hot if the current is high enough.«
Yes, IF the current is high enough. But just with the inverter connected to a small primary coil (transformer like arc welder but not size and power like arc welder) there is no need for the loop to get hot, tried it myself. If it starts to get hot nevertheless when HV is connected, then this would be a sign that something extraordinary is going on.
Void: » For some reason you continue to ignore these things and still insist that Barbosa and Leal devices
produce over unity.«
Not for some reason, but for good reason. The Kapanadze device seems to work, as we know. So there is no reason why the Barbosa-Leal device should not work, since there is most likely just one principle for that kind of devices. And very strangely Bearden describes exactly this principle in a paper from 1982 (see previous page).
Void: »this type of ground loop problem should really be common knowledge«
And that problem would be? When I connect an incandescent lamp with one side to phase of an electric socket and the other side to a water tap, then is it this what is called a ground loop? Maybe, but this does not interfere with my electricity meter. It continuous to meter every milliampere that goes through the lamp. So what ground loop is it, that could have misled two people familiar with electric equipment at once? Don't know.
Besides I have pointed out that there is no ground loop. The input from grid or inverter can be completely isolated from ground.
Void: »the earth ground wire does nothing no matter how I wound it around the captor loop wire or connected it to the captor loop wire«
Then the most reasonable assumption here would be, that something minor is wrong or missing. Any constructive feedback would be much appreciated instead of keeping saying researchers should better quit.
Hi Heir Time machine how much current do you need ?  2-3 kv of the grid is a bit leathel and will the insulation in the windings go that far ? all you need is a power FET 6volts on a larger ferrox cube or ring primary 8 to 12 turns 18swg depends on current and 8 - 12turns feed back with 220 to 470 r in gate feed back loop and a secondary 600 t insulated layers iif its ac you will need 1200 or more depending on input volts but it will be highly efficient. Works for me.
leo48
 ;D
Guys ... I found a youtube of 2004 kapanadze to which subtitles were added in Russian but it is possible to translate them ..
https://www.youtube.com/watch?v=5s2t_puDDhI
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
itsu
Quote from: TinselKoala on January 16, 2018, 11:34:08 PM
No, of course not. In fact I have not even built the full EEEE system (yet) due to lack of space (ironic isn't it) and funds. I am "suggesting" that the devices I have designed, demonstrated, proposed and explained perform all of the things which others have suggested as the "secrets" of overunity. People are flailing around without any coherent scientific theory or well-formed testable hypotheses, not to mention the chasing of hoaxes that will never result in any payoff but will simply waste the time, energy and money of well-intentioned, hopeful, but naive experimenters (if they can be called "experimenters" at all rather than simply misguided hobbyists.)
Very interesting TK,
i am sure you got the attention of some people, you sure got mine.
Is there a possibility to open a new thread on your "Apparatus for Entraining Envirmonmental Electrical Energy (EEEE) v2.2"
so these interested people can start gathering components and join you into a build?
Regards Itsu
