Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Zeitmaschine
But there are no transistors on the 2004 device heat sinks. See illustration on page one.
Looking at the Stepanov three-phase transformers, there is no way driving them with transistors. But if that HV transformer is not a HV transformer but a step-down one and it is connected in reverse to a frequency doubler circuit, then that frequency doubler circuit could generate somehow sharp high voltage pulses on the primary coil.
endlessoceans
Quote from: ariovaldo on January 17, 2018, 03:09:06 PM
The same of the above schematic.
Tinsel is 100% correct
Ignore all the nonsense coils on that schematic and simply follow where the HOT line from the mains goes.   The coils do nothing except attempt to pseudoscience the fool.   The Neutral return is not used but instead is sourced through the ground and thus bypasses the meter stealing from the grid.
This method will work in any Country which has SWER.  2nd and 3rd World usually.  Why do you think Barbosa and Leal restricted sales to their home Country only????
Wake up
Outside of that there are many beautiful methods for energy harvesting but the Barbosa is just theft pure and simple.
Void
Quote from: Zeitmaschine on January 17, 2018, 05:20:47 PM
Hi Zeitmaschine. Then what type of components do you think are mounted on the
two black heat sinks on the far side of the tobacco can? It does look like there may
be only two white wires going to each component on the heat sinks, but there could
very possibly be a third wire going to each component that is not clearly visible. If I
had to guess, I would guess they are probably transistors on those two black heat sinks.
All the best...
Zeitmaschine
Hot diodes on heat sinks make no sense, capacitors should not need a heat sink, so what's left are two resistors.
Void
Quote from: Zeitmaschine on January 17, 2018, 09:05:18 PM
Hi Zeitmaschine. No, I doubt they are resistors mounted on heat sinks.
I would guess that they are probably power transistors, just as were also used on the green box device.
All the best...
