Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Hoppy
Quote from: AlienGrey on February 05, 2018, 11:38:30 AM
Looks a right birds nest! haven't you fathomed out how it works yet ?
I have a good idea how it works but does not work as claimed.  ;)
ramset
Fernandez quote
All of you are guilty of applying traditional thinking to a device that doesn't work in traditional ways.
Ok, look stop thinking about PRIMARY and SECONDARY. It just doesn't work like that. Forget the secondary its just a coil to remove energy THAT'S ALL. Also forget funky coil winding like bifiler...etc.
You need to build a resonator, start with iron, cut a tire iron into a straight piece, using a C-Clamp will close the magnetic circuit. Thats cheap and easy. There are two primary coils, A/C input or pulsed will be ok. Also its 1/2 wave each coil (PRIMARY) Get that iron moving, can you get it to vibrate real fast? or can you get the energy to chase its tail? How hot can you get it with low power?
Of course a secondary coil is used to remove energy BUT you need to collect it first so forget the secondary and build a resonator.
Good Luck.
end quote
Sir
this sounds a lot like a path member Verpies had  suggested.
Not meaning to distract here
could you draw a simple block schematic for this suggestion [C clamp placement, primary orientation etc etc ]
seems too easy to not try !!
respectfully
Chet K
Thanks Grandma
Sergh
Quote from: Zeitmaschine on February 04, 2018, 09:30:08 PM
Fernandez: »Your not entitled to call anyone anything.«
Sure. But Kapanadze and others are entitled to give us (and the whole world) the run-around? Think about that.
Fernandez: »Of course a secondary coil is used to remove energy BUT you need to collect it first so forget the secondary and build a resonator.«
Like this? Does the aquarium wiring of the three-phase transformer look familiar when compared with the second schematic above? Drawing from page 873.
If both 0.5 Ohm coils are low voltage then the 88 and 80 Ohm coils are high voltage connected in parallel and one side to ground. The 78 Ohm coil (third transformer) is not needed, thus not connected. Is one 0.5 Ohm coil connected to the frequency doubler circuit and the other 0.5 Ohm coil to the load? Since that device is not connected to grid or inverter, the frequency is unknown. It could be 200 and 400Hz instead of 50 and 100Hz. So, is this all hidden in plain view? Are we closer now than ever and we can end that nonsense game soon?
This is a small 3-phase transformer from the Soviet clone IBM-360  MainFrames (  EC-EVM )
https://en.wikipedia.org/wiki/ES_EVM
Its output power is about 200 watts.
After dismantling and recycling in the late 90's a lot of these transformers ended up on landfills and flea markets.
They are not suitable for use in the household.
Transistor TESLA in the background from the factory "Tesla"  in the former Czechoslovakia.
https://en.wikipedia.org/wiki/Tesla_(Czechoslovak_company)
It has nothing to do with Elon Musk.
Ordinary transistors from flea markets, feature - relatively high-frequency, but not very high:
KU601    NPN,     50V    3A    20..73    10W    TO-3
KU602    NPN,    80V    3A    20..73    10W    TO-3
KU605    NPN,     80V    10A    10..50    50W    TO-3
KU606    NPN,     60V    8A    10..50    50W    TO-3
KU607    NPN,     80V    10A    40    70W    TO-3
KU608    NPN,     80V    10A    >10    70W    TO-3
KU611    NPN,     60V    3A    20..90    10W    TO-66/1
KU612    NPN,     80V    3A    20..90    10W    TO-66/1
Sample
Jeg
Quote from: ramset on February 05, 2018, 01:27:54 PM
Sir
respectfully
Chet K
Hi Chet :)
Is it possible for a link to Verpies suggestion? Out of Fernandez description looks like Leedskalnin PMH?
ramset
Jeg
Verpies and others feel that NMR Could be a path to this result [harvesting from the reaction]
It is this "resonator"  {NMR} which I believe Fernandez refers too..... two "half wave" coils [NMR frequency of iron ??]
Your leedskalin PMH architecture does seem how it would be built ?
the "Chasing" comment...
I would love a block diagram/schem to be certain ?
and it also has a TPU ring to it if this is true [circular drive /PMH ??
I like the concept of looking for heat at lower than normal inputs... but would appreciate a bit more direction and feedback.....
as I am sure many builders here would too.
bench time is a very precious commodity .
respectfully
Chet K
PS
Verpies did post many charts for NMR frequencies ...they are available in web searches.
however I would like to check against Verpies Charts [He's a schmart guy
Thanks Grandma
