Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Jeg
Quote from: ramset on February 05, 2018, 05:29:05 PM
Jeg
Verpies and others feel that NMR Could be a path to this result [harvesting from the reaction]
It is this "resonator"  {NMR} which I believe Fernandez refers too..... two "half wave" coils [NMR frequency of iron ??]
Chet
For sure NMR is very interesting, i just have the feeling that Fernadez spoke about mechanical vibrations. Two coils as a primary, each coil conducts for half of a cycle and the result might be a vibration of the free part of the iron. Higher frequencies than what iron can follow for sure will heat the iron into high degrees even with low power. I hope Fernadez will clarify a little more about his proposal.
ramset
Jeg
yes it would seem a bit of clarity would be very useful
here a comment from the AVEC TPU document
If you pulse iron wire at iron's NMR you'll get a minor resonance effect even if the coil is not tuned to that frequency. Steven Mark was utilizing this effect along with the timing delay action of iron wire to generate a rotating magnetic field of the correct frequency.
end quote
respectfully
Chet
EDIT
PS member Grumpy [reborn as Sigma16 after some moderation episode [he is very passionate about this [and I don't think Sigma16 survives unmoderated today   :o]
started a topic here on the AVEC [with links]
http://overunity.com/9749/aether-vortex-energy-converter-avec-device-full-disclosure/#.Wnm-YbmWzoY
Thanks Grandma
Jeg
Quote from: ramset on February 06, 2018, 08:50:44 AM
end quote
Nice. Normally the frequency is dependent of the perpendicular magnetic field's value. I hope that we can find some more info on this.
Zeitmaschine
SOME CONSIDERATIONS
First: Any idea, how Tesla's fireball machine can generate nuclear magnetic resonance since it has no iron core and how nuclear magnetic resonance could be accountable for a ground current? In my understanding nuclear magnetic resonance wouldn't need a ground connection at all.
I would rather suggest, the Kapanadze, Stepanov and Barbosa-Leal devices are just open electric systems. Such a system simply defeats Lenz's law and Ohm's law by connecting to the ambient medium as a source of energy.
Second: What would happen if we replace the 100Hz transformer by a switch also working at synchronized 100Hz? We have an open high voltage secondary coil working at 50Hz that attracts electrons from ground via a ground connection on one end and then we short it when the sine wave is on its peak. Could it be, there is no real need for a second transformer working at 100Hz? Just a fast bipolar switch working at 100Hz? Of course the problem here would be to find a switch that can withstand a few kilovolts. On the other hand, this could be the reason why almost no hobbyist can discover that effect by chance. Or should the switch better work at the 50Hz grid frequency? Anyway, I don't think a simple spark gap as switch will do it in that case; it's just too unsteady and too unreliable. But what, if the primary coil of the 100Hz high voltage transformer would not be connected to a frequency doubler circuit, but to a switch that shorts its primary coil synchronized to the grid frequency? So the periodically shorting of the high voltage coil is made through that transformer and therefore a switch for low voltage would be sufficient. There are two transformers and their secondary high voltage coils are connected in parallel and to ground. One transformer generates high voltage (step-up) from 50Hz grid, the second transformer steps the high voltage down again to low voltage. Now, if we short that low voltage coil of the second transformer, then the high voltage is also shorted. Strictly speaking, the second transformer works like a magnetic amplifier.
cosmoLV on October 04, 2010, 03:48 PM:
»P.S.
http://sparkbangbuzz.com/mag-amp/mag-amp.htm
try combine it together«
Tesla: »Under these assumptions the energy would flow through the path O, as indicated by the arrow, and might then be converted on its passage into some other form of energy.«
Means, the energy - the negatively charged electrons from ground - would flow into the high voltage coil which works as an energy sink, then, by shorting that coil, the energy might be converted into an other form of energy, namely a strong magnetic field.
Just pondering ...
Sergh
About NMR:
There are many ready-made devices, containing chemical compounds of iron,  that use various effects based on NMR.
For example:
QuoteYttrium iron garnet spheres (YIG spheres) serve as magnetically tunable filters and resonators for microwave frequencies.
https://en.wikipedia.org/wiki/YIG_sphere
QuoteAn isolator is a two-port device that transmits microwave or radio frequency power in one direction only. It is used to shield equipment on its input side, from the effects of conditions on its output side; for example, to prevent a microwave source being detuned by a mismatched load.
https://en.wikipedia.org/wiki/Isolator_(microwave)
As far as I know, no one noticed any presence of overunity in these devices...
