Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
AlienGrey
Quote from: tinman on February 11, 2018, 07:35:52 AM
Couldn't agree more Void
As you may have noticed,i have been absent from the forums for quite some time now.
I am only here now because Chet pointed out a post via email,and so i came to have a look.
I see most are still lost when it comes to understanding induced EMF and currents,and what the outcome-or bi-products of either are.
So many still believe that the magnetic field is the master,when in fact it is a hindrance-->a bi-product of the flow of current through a conductor.
Only when people understand that it is the electric field of a primary coil that induces an EMF across a secondary coil,will advances be made.
Brad
I thought ether was what they use to use in hospitals  :)
Everything is energy (electric energy) magnetism is something else but it's not gravity, what you call ether is electricity, (to convert magnetism to electricity has a price to pay), (uncharged neg electrons ) with respect to other electrons, if you want energy find a way to raise a potential between them and get them out of there holes, find a way to do that and it's all around you, Edison had the opposite problem
that's why he employed Tesla he solved it or right with AC it killed it, so what does that prove come on work it out and don't give up so easy.
Regards and good look, Allem
ramset
Iron needs a closer look IMO
Steven Mark mentioned a very similar ring back from the ambient with iron
And such an apparently simple experiment as Fernandez has proposed [almost proposed],on the proper bench
Should show the claimed effect rather quickly.
A block schematic would be nice to see
And perhaps a frequency suggestion too.
Respectfully
Chet
Thanks Grandma
Jeg
Quote from: ramset on February 11, 2018, 10:53:51 AM
Respectfully
Chet
If you have something different in mind please share it.
Jeg
Guys I always play with higher frequencies in the order of KHz. Keep in mind that 50Hz is lethal. At this low frequencies most probably will follow heat smoke and eventually a shortcut between turns.
seaad
