Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Hoppy
Quote from: Void on January 07, 2018, 05:10:26 PM
Hi Hoppy. I am not following you. If that account about the remote island test is accurate, then
it was the investors who arranged to take Kapanadze to the location of their choice. Their people were
attending the event in person. They weren't watching a video. As the account of the event goes anyway. :)
I wasn't there so I can't personally verify the details however.
All the best...
Hi Void,
How can we be sure that they were all real investors and not just a hatched plan to lure real investors. Yes I know that this sounds far fetched but TK needed money and people will go to great and risky lengths to obtain it.
Void
Quote from: Hoppy on January 07, 2018, 05:17:50 PM
Hi Void,
Hi Hoppy. I did not say it was proof of anything. I was just relating what has been posted
in the past about what supposedly happened. Kapanadze's demo in Turkey where the
generator was generating quite a lot of power in front of a lot of people would also be hard to
fake I think unless the Turkish investors which Kapanadze was dealing with at that time were
also part of an elaborate plan to scam everyone.
People can go to some pretty far lengths to try to explain away things, but some of those speculations
seem more far fetched to me than the possibility that Kapanadze's devices might possibly be doing just what
Kapanadze claims and demonstrates they do. That's just me however. Everyone is entitled to their own point of view. :)
All the best...
AlienGrey
lets look at one of TK's devices notice his spark gap, how fast a pulse would you say it takes to start to finish,
what i'm saying is how wide would a pulse be if you were to measure it ?
Next question draw a circuit to emulate it !   8) 8) 8) ;D
recon you can crack it ?
Void
Hi AG. The sparkgap sparking has appeared different in different Kapanadze demos.
I think it may be a good idea to focus on Kapanadze's 2004 device since that setup
was very basic and may possibly not have had anything much extra added as decoys to try to
throw people off track. In a translation I read of that 2004 video, Kapanadze apparently said
the sparkgap was sparking at 50Hz. As for the spark duration, I don't think you can tell that
from the videos, but from the looks of the sparking in the 2004 video, it was low current.
However, anything Kapanadze has said should be taken with a grain of salt as you never know
when he is being straight and when he might be just trying to throw people off track. There
lies a big problem with trying to decipher what really may be going on in Kapanadze's devices. :)
All the best...
wattsup
Quote from: Hoppy on January 07, 2018, 03:31:40 PM
A fresh approach to the mystery maybe.
Yes agreed, the TK coil winding is very likely eye candy.
Yes agreed, the output is probably pulsed.
A MOT is perhaps the easiest and cheapest means (scrap yard build) of producing the HV.
However, what is the source of energy? If its from the grid, then we have a place to start. If so, do we assume that the grid current is supplied from a remote location to the device? If not, what is the source of energy local / within the device?
Could TK have sent the HV over very thin cable from a remote location?
To minimise energy consumption whilst producing highest lumen bulb output levels, do we need the HV to ionise the gas in the bulbs?? Has anyone experimented with pulsed HV transformed from the grid, directly applied to incandescent lamps at various pulse rates?
@Happy
At this stage the power source in not important. We already know that pulsing a HV transformer at the primary resonance and sometimes at the secondary resonance will consume the least amount of energy plus we also know that at resonance the secondary usually outputs at its highest voltage. The idea is to take that voltage and cut it down to usable volts while layering the voltage so the amperage increases as well. Think of it like a mosfet step down transformer without the transformer.
There are not 10 principles of the Green Box. Usually it take a lifetime just to find one principle let alone two or more. So the whole TK device is not working because of many variables. He is putting in all those extra dodads just to keep you off his track.
About patents TK or other, forget it. He would never put his secret in a patent because a patent is a business tool, not a knowledge tool. No inventor will divulge everything in any type of OU patent.  They will always keep the real function out of it and use the patent as an investor tool. Some inventors will even patent non working devices just to get their name out there so that if someone else ever worked a real device, they could use the patent to get compensation. But that is not a guarantee.
Research in OU is like research in everything else. You try one angle and see if it leads to other angles and from there you begin to make a portrait of the effects you want and one day bingo, you get it. TK obviously did not invent a knew way to produce high voltage. We can see that in the device @stivep saw when he was in Georgia. It had a pretty standard HV device showing. He did not invent a new spark gap. We saw that as well. The only thing I can think of is he is cutting the high voltage into manageable voltage levels hence the two toggle switches on the Green Box. The other TK devices use a 9v starter voltage. So can you start pulsing a HV primary with only 9 volts and loop it so it grows on itself. Yes you can and if the primary is taking less energy because it is in resonance and if the secondary HV can be cut down to produce more volt/amps/watts then what the primary is consuming, then there is a chance it could work.
wattsup
