Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Void
Quote from: wattsup on January 07, 2018, 06:49:28 PM
About patents TK or other, forget it. He would never put his secret in a patent because a patent is a business tool, not a knowledge tool. No inventor will divulge everything in any type of OU patent.  They will always keep the real function out of it and use the patent as an investor tool. Some inventors will even patent non working devices just to get their name out there so that if someone else ever worked a real device, they could use the patent to get compensation. But that is not a guarantee.
Hi wattsup. No one suggested Kapanadze's patent applications contained all details or that
all was accurate, but the fact that he makes the coils an important part of the patent applications
would certainly seem to imply that they are an important part of his device. If Kapanadze's patent
applications did not represent in some sort of reasonable way the actual device and principle
behind it, then someone could patent or produce Kapanadze's devices without the coils and Kapanadze's
patent applications would be useless to protect him. :)
At any rate Kapanadze's patent application were just too vague to ever have a chance of being
approved anyway, IMO. You can't tell from his patent applications what the heck he is exactly patenting
except that it has some coils and supposedly does some sort of current magnification. Patent applications
have to be a lot more detailed than that to have a chance of being approved unless the patent examiner
is taking bribes or they are a drunk. :)
All the best...
core
Regarding Barbosa and Leal
Barbosa goes by the name Nilson da Ampere on the internet. I do not think he is on Twitter anymore but you can tweet him @NilsonAmpere. They both have started a new company and have added a 3rd partner. Name of the company is Evolucoes Hidrogas and the website is http://evolucoeshidrogas.com.br/web/english/
This new company has found a way to create hydrogen gas from water using no electricity.
-Core
Side note: This patent is cited in the Barbosa and Leal patents (The electricity-generating circuit WO 2007019869 A1) what is interesting is the author uses the term converter and not transformer.
https://www.google.com/patents/WO2007019869A1?cl=en
Belfior
TK device is something so simple he is very paranoid about even showing it to people for close inspection. There is no other reason why he would add crap to his devices like old TV back panels under everything and paint the components black.
He got the idea from a multi phase transformer so the device is something like primary, secondary in resonance feeding back to the driver like a slayer circuit and then load coil on the same ferrite. Maybe the load coil is open ended and going to a load and the other side of the load to the ground. He wasn't using much components.
What I don't get is how he gets the 50Hz output if he uses a spark gap. The timing is not that presise
Hoppy
@Happy
At this stage the power source in not important. We already know that pulsing a HV transformer at the primary resonance and sometimes at the secondary resonance will consume the least amount of energy plus we also know that at resonance the secondary usually outputs at its highest voltage. The idea is to take that voltage and cut it down to usable volts while layering the voltage so the amperage increases as well. Think of it like a mosfet step down transformer without the transformer.
wattsup
Hi Wottsup,
In an LC circuit, we either have series resonance where the current maximises at the expense of voltage, or parallel resonance where voltage maximises at the expense of current. Neither of them offer an increase in overall output power with respect to the level source power. Looking at it in terms of energy sourced and expended, we just add time to the equation. Are you suggesting that by somehow layering voltage, we can overcome this relationship?
Hoppy
Quote from: Void on January 07, 2018, 05:32:50 PM
Everyone is entitled to their own point of view. :)
All the best...
Yes indeed Void! However, I think to be fair to Wottsup, we now need to direct the conversation to a technical discussion about how TK may have achieved a self-running device along the lines Wottsup is suggesting.
