Pulse Motor Video
Started by awesomo4000, November 28, 2006, 06:26:02 PM
CLaNZeR
Quote from: msurucu on January 21, 2007, 12:53:32 PM
is there any differences from step motors?
Well main difference is that a Stepper motor is input only. So you have a number of coils inside a stepper motor and power is applied to all coils, this keeps the motor in a static position. Then you pulse each coil in the correct sequence to get acurrate movement. Common Steppers take 200 pulses for a full revolution, so excellent for CNC/Milling machines where accuracy is needed.
The pulse motors shown are moving the rotor away or towards the coils by a simple pulse to a electromagnet, but also there are coils that are pickups to collect the energy created by the magnets passing over them, again around the rotor.
So basically the idea with a pulse motor is to get more energy produced by the coils around the rotor than the energy used to drive the other coils that act as electromagnets.
After months of watching ebay to get some decent priced electromagnets, today I actually spotted some that look ideal for a pulse motor and won a bulk lot for a good price. I could of wound them myself but wanted manafactured graded ones that have equal power. I will probably have to wind the pickup coils myself, but in saying that there are a few Motor Bike Stators going cheap on ebay that may be ideal.
Sean.
http://www.overunity.org.uk
msurucu
but i think step motor can be used as a pulse motor.
some step motor have a permament magnet rotor.
here some step motor images.
and link  http://www.interq.or.jp/japan/se-inoue/e_step1.htm
CLaNZeR
If you say pulsed coil 1 and 3 to drive the stepper, are you going to get more power out of the coils 2 and 4 to created more power?
You could pulse a stepper and it would turn and pull alot of current as it is designed that way.
You could attach a wheel to a stepper and use it as an alternator, at low revs they work fine, but as soon as you speed them up you get alot of resonance back.
Sean.
molux
Hy,
I'm french, and i have some problems to understand all on this website:
http://www.mintakafulcrum.net
1 - In this uTube page http://www.youtube.com/watch?v=f4gAKrn5pl4, the video publisher said:
The motor uses about seven watts of electricity, yet the mechanical output is 4 to five times that of the electical input. I hope that helps.
2 - Does someone find this information on the website http://www.mintakafulcrum.net, and wich motor model who do that ?
This motor seems efficient, can someone work on it ?
Molux
ian
Hi everyone.
I am the builder of the motor that was posted here. Stephan asked me to come by and discuss it.
I just posted a new video here:
http://www.youtube.com/watch?v=5oIZTZeC6c4
This is just a demonstration to compare with the other motor first posed here. The rotor is the same. The coil in this one is about 1.2 ohms and is bi-filler wound with the second coil picking up the bemf.
This uses the same amount of power running with one coils as the other motor with eight coils. Yet this one I can stop with two fingers, and the other I could not stop with all of my strength in my hand without burning my fingers
The single coil motor here runs at 2325 rpm and the one with eight coils at 2400 rpm. So they run at virtually the same speed and power input (~7 watts), yet the torque and hp on the eight coil unit is much greater for sure. Sorry I don't have prony brake numbers for you all. I put on on the eight coil model and it bounced to much to get a good reading.
The four to five times power mechanical power output is my best guess by comparing with trying to stop the eight coil motor from spinning with that of an AC fan that was rated at 45 watts...
