Thanks to ALL for your help!!
new approach on a gravitational engine
Started by santiagopanduro, December 27, 2017, 08:23:28 PM
iacob alex
  Hi !
The history of perpetual motion machines dates back to the Middle Ages ,including the most common design ( "self" overbalanced wheel concept with hinged arms ) , as :
https://en.m.wikipedia.org/wiki/Perpetual_motion#/media/File%3APerpetuum1.png
So, what can be the "new approach" if we apply the redundancy rule (minimum minimorum) regarding a possible continuous gravity overbalance ( "self" motion due to a continuous torque difference on the same side of the fulcrum ) ?
As you know : no flow,no power .Let's "free" the gravity full motion , if you intend really to draw out "motion from the natural ( free... ) motion "...
Simply : use the gravity acceleration "via" the increasing velocity.
Al_ex
citfta
Quote from: iacob alex on February 03, 2018, 04:54:26 PM
Hi !
If so...type on youtube "Evolution of Perpetual Motion.WORK of Gravitational Power!",then search...
Al_ex
Here is the link:  https://www.youtube.com/results?search_query=evolution+of+perpetual+motion%2C+work+of+gravitational+power
That video is very suspicious because he does not let it continue to spin and make a full revolution.  There is probably a hidden weight that is causing the wheel to turn.  If you watch closely he always stops it at the same point and then turns it backwards.  If it really worked he could stop it anywhere and then let it go and it would start again without him having to  turn it backwards first.  Most likely a fake.
Respectfully,
Carroll
sm0ky2
His spokes are out of adjustment
Tighten them up and it will balance
and be perfectly motionless
iacob alex
 Hi !
Try to play the same youtube wheel concept , as a "minimal" design : two opposite hinged spokes ,only.This can  be a simple variable lever , intended to maintain a continuous gravity unbalance ( due to a torque difference on the same side of the fulcrum ).
Al_ex
iacob alex
   Hi !
A "minimal" design (easy to be tested...) , can be expressed as :
http://www.geocities.ws/iacob_alex/Some_Drafts/text028.JPG
  The main point is to "tumble", to roll end over end the torque difference on the same side of the fulcrum.
  Simply , the wheel becomes a lever...
  Al_ex
