new approach on a gravitational engine
Started by santiagopanduro, December 27, 2017, 08:23:28 PM
iacob alex
  Hi !
Related to the same approach ( wheel concept ) , take a look at :
https://youtu.be/SA7nol8sHL8
It's a very old approach (Middle Ages...Leonardo da Vinci,Bessler's MT13...) seemingly unworkable...due to the starting concept,in my opinion.
So , if we apply the redundancy / unnecessary repetition in this wheel design /...we can evolve and hope for a successfully test...simply, a lever(age) but not a wheel.
  Al_ex
norman6538
Quote from: iacob alex on February 03, 2018, 04:30:50 PM
  Hi !
https://youtu.be/SA7noI8sHL8
  Al_ex
youtube says video not available....
Norman
norman6538
Many many very fine folks have worked very very hard for many years and have
not cracked it.  But then comes along the guys who say they have it figured out and
all have come to nothing....
So the problem as I see it is with either permanent magnets or gravity power you have
to set something up to do some work and that is easy then the power is there but
it then has to be set up again to repeat that. I call that the "reset problem". It takes
some work to reset for the repeat. I had one wheel that would reset itself by gravity
and it would turn a bit but it did not continue on far enough.
In Bessler's case his 1st wheel always wanted to turn and it had to have a brake to
hold it still. Pull the brake and off it went....
Bessler and Tesla and Moray and Stan Meyer and Skinner took some great stuff to their graves.
I really wish it were otherwise.
Norman
iacob alex
 Hi !
If so...type on youtube "Evolution of Perpetual Motion.WORK of Gravitational Power!",then search...
Al_ex
Les Banki
Quote from: norman6538 on February 03, 2018, 04:50:40 PM
Norman
Norman,
The trouble with you is that when you are given information, you IGNORE it and you continue THEORIZING, instead of doing REAL work!
May I suggest that you get onto Facebook and check out Kevin Hay and his work.  Make sure you get the right Kevin Hay.  He is in British Columbia and he owns and operates 'Vancouver Island Ormus'.
He has EVERYTHING worked out to PERFECTION and he also explains EVERYTHING you need to know!
No ifs, no buts, no maybe's.
STOP arguing and just follow his directions!
Cheers,
Les Banki
