The answer has been given, but it was deliberately removed.
Started by Turbo, December 28, 2017, 09:05:22 AM
Toolofcortex
Wrong! Silly pretenders to the throne, you are unworthy. Exept Bruce, he is a man of god, a wise man.
SM was creating mass nodes by using harmonics, wich is the only way to get mass nodes actually. Its basically cheating the conductor and putting more density there than you could have in the beginning of all the mass rendez-vous point, the action-zone is what I like to call it now.
For a given voltage, when dealing with non homogenous charge distribution impulse signals ( it can be AC) vs transmission line lenght, only harmonics creates mass nodes.
I'm not talking lumped circuits. Thats all same charge distribution.
Heres an analogy, radars use a soliton wave to shape a pulse, well SM uses a train of harmonics to create a mass node with the Standing wave.
And  timed deflectors, to collector transfer. The charge is stripped away (exploded) just like carbide vs metal, buts its a double side type of thing.
But all this theory is testable in non-toroid form.
Examine, the sun.
Bob Smith
Quote from: Toolofcortex on February 21, 2020, 08:20:44 AM
Examine, the sun.
I like what you say, having seen interesting things on the scope with multiple harmonics many years ago when tuning a transformer circuit of sorts with a variable resistor. At this point, I'm more partial to the idea of heterodyning frequencies to produce a standing wave. I wonder if we're in the same ball park.
Do you see a zener diode (and avalanche breakdown) having any role to play in the TPU-type setups?
Bob
Toolofcortex
Not heterodyning.
I said same voltage, not same source. Not heterodyning.
Consider the power present, consider the incoming mass, from another stream, merging.
Consider 3 sources, you can even consider them isolated by diodes.
Its a bit confusing in the beginning, multi-source systems. Buts its really not.
Grab a Sim, you'll see what I mean. There is an area that can be pinched magnetically, this area is double direction and high density, this is the goal.
In this area there must be accelerating and strong vector, for boundary crossing.
This is Kirchoff rules, how do you maximize density with the same voltage? I just told you... The harmonics hack with SW.
Play with the harmonics of a non homegenous wave (compared to lenght of Transmisssion line).
You can match the nodes, have varying intensities along the apparent non wave with non-intensities.
I believe that once the initial "cut intensity" is done, then the mass simply flows.
The bucking field must be intense and accelerating, and density as high as we can get, or perhaps as efficiently as we can get.
Toolofcortex
https://pdfs.semanticscholar.org/9787/653cd51d2ae8adaa43a907fcb66d37871f11.pdf
https://www.google.com/search?q=Alfv%C3%A9n%E2%80%99s+Heliospheric+Circuit&tbm=isch&sxsrf=ALeKk02qwpdmri-g7XgQuUZH3i7biCgLgA:1582144974807&source=lnms&sa=X&ved=0ahUKEwi2g9Opvd7nAhVBOs0KHWP7COsQ_AUICigB&biw=1164&bih=866&dpr=1.1#imgrc=ns_xOibFhmTOVM
The sun blurps out particles in pulses.
It, unlike our electrical circuits, can offer itself much relaxed time scales and much more mass. And much greater magnetic fields.
So we, must be extremely creative in our methods to even attempt to replicate self powering generating mechanics of this celestial body.
Be jealous of the sun...
But certainly, to use positive energy against itself is one ofthe primary foundations.
https://www.scienceforums.net/topic/83317-electromagnetic-solar-systems/
Bob Smith
Quote from: Toolofcortex on February 22, 2020, 08:47:11 AM
Not heterodyning.
Thanks for the helpful clues. Makes sense to me.
I do believe this is doable in a small way in a relatively simple fashion.
I'll sit with this for a while, maybe post later if time and health permit.
B
