inertial propulsion with gyroscope
Started by woopy, January 16, 2018, 04:39:01 PM
woopy
I all
Thank's for compliments on my replication. But it should certainly be redone and more precisely, because this thing deserves a high craftmanship.
to TK
Yes i aggree that a test on the marbles should be done, but as me, you know that, to be convincing (good or bad) in this case, the DUT should be a (at minima) twin system running perfectly in opposition and also in perfect synchronisation to avoid the latteral parasite mouvement due to the  spinning asymetric mass. And frankly i am not sure to be able to realise such a device. But perhaps somebody else could try.
As you have correctly noticed, the device make a slight mouvement backwards and almost double the mouvement forwards. M. Fiala explain this in the patent. But i understand that it is a long and boring time to read the 33 pages of description of the patent.
I am not a seller of space propulsion devices, i am simply fascinated by this device, which can surprisingly also coast slightly.
Just for fun, as you seem to know very well the subject, would you be so kind to explain in simple words, how the old M. Laithwaite manage to lift the big wheel, and seems to withstand the centrifugal force so easily as per this video.
https://youtu.be/JRPC7a_AcQo
And for info i did the big wheel experiment with a lighter cart wheel (about 4 kg) spun with a grinder, and i have really the impression that it goes from itself around my head. But perhaps it is only impression, but what a great impression. Perhaps i have an addiction to be fooled.
Thank's
To Chet
I have not quite undestood what TK wanted to speak about precession. Can you eventually explain his words
Thank's
ramset
Woopy
Honestly?
I'm confused
when I take the big 1hp hand held grinder  with the 14 inch diamond blade [for cutting concrete]
and run the blade up to 2-3000 RPM and move WITH precession,  I can relax certain muscles ...it feels lighter ,
and that is not a heavy blade [the saw is very heavy tho]
I did this "with precession movement" all the time in demolition business with similar very heavy gas-powered unit with Big wood cutting 12 - 14 inch carbide blades
it was a method to Move and not have to carry the full weight of the saw when working on ladders and repositioning
for another cut.[sort of cheating]
rev the saw and move with precession
if you put a scale under me on the ladder or Mag's barstool when the teacher spins ..or if you stand on a scale when "you" spin
no weight loss....try it.
but ...why did I use this "with precession movement " to rest my muscles when working up on the ladder [to move the very heavy saw to another Cut ??
makes no sense ....
and just Like you {and Tinsel too } it hurts the head....
and all agree it needs more looking and measuring and ...
perhaps a better method to measure this localized apparent weightless which cannot be seen on a scale ??
IMO there is something there which all here  agree... needs more investigation.
Confused but grateful [for you and your work]
Chet
Thanks Grandma
Paul-R
For me, the interesting variant was a square piece of heavy ply with four electric motors at the edge of each side with shafts facing out.
Each motor had a heavy flywheel, and they rotated in the same direction, facing north, south east and west. When started up, the platform became heavier or lighter.
If heavier, it would be turned upside down, so that on rotating, the device should generate more lift than its weight, i.e. float. But I cannot find either the photographs or description.
This isn't the page but close. Look down the page to the image of the blue base, green motor/flywheels and  red arrows pointing upwards.
https://www.intalek.com/Index/Projects/SmartSPIN_X2/SmartSPIN_X2.htm
woopy
I Chet
very informative the fact that your big grinder seems lighter in precession. And that you use this caractéristic to relax your muscles.
I found this video, where"veritasium" replicate the Laithwaite experiment standing on a scale, which shows no weight loss.
Then it tries some explanations but i am not convinced at all.
At 2.50 he try to turn backwards with the big wheel spinning and he can simply not lift the wheel to face the caméra.
Perhaps he should have done this also on the scale to see if there is a weight gain when you go counter precession ?
https://youtu.be/tLMpdBjA2SU
Hi Paul R
Thank's for input
laurent
