I did NOT see any chemtrails today.
Started by MagnaProp, January 18, 2018, 12:18:00 AM
sm0ky2
An (almost) identical molecular structure is found in anything organic
this includes most of our foods,
and by proxy, most hydrocarbons and their synthetics
you can have even more fun by comparing this to the molecules
found in dmt, cocaine, sugar, carbohydrates
now look at all of the chemical receptors found in our bodies.
With a few exceptions (thc, thyronine, adrenaline,...)
the rest of our bodies are designed to intake this particular
molecular construct.
and the similarities between the different molecules allows them to
replace each other on a biological level.
then think about how our bodies intake solids, liquids, and gasses
by eating, drinking, breathing, absorbtion through the skin, eyes, and ears.
absorbtion inside the nose of everything that was trapped there.
things we step in, swim in, touch on every surface.
many of these organic molecules may only vary by the placement or
addition of a single ion.
then you can be a hermit who is scared of aluminum foil
but wears it on his head to protect from the impailing sodium and potassium
from the sky.
after that you can become a mycologist, and go insane
by then we will probably be using a new type of jet fuel
for regulation purposes we'll call it type Jet C
and your "chem trails" species will then have a 3rd genus.
gravityblock
Quote from: sm0ky2 on January 21, 2018, 12:05:55 PM
from the sky.
Smoky2 thinks crystal methamphetamine and toluene is as safe as most of our foods...ROFLMAO!!!
Take another hit off your crack and meth pipe Smoky...  It's clearly obvious you have already taken one too many hits!
Gravock
sm0ky2
sm0ky2
Smell a carbonated soda from an aluminum can, I can prove that your nose makes Butane.
We're not supposed to eat the casing of a corn kernel.
It's about as nutritional to humans as a piece of plastic.
but good luck convincing people to stop eating it.
MagnaProp
Quote from: sm0ky2 on January 18, 2018, 06:13:49 AM
It's a good thing we chose commercial jet fuel to inflict our conspiracy theories on.
Lets assume for a moment all that smoke is from normal commercial jets and their fuel.
Explain to me the flight paths they are making. Some of that "commercial jet fuel" clearly indicates they are making at the very least a U turn. It isn't obvious from the compressed video quality but I could see while shooting the video that a couple of the planes kept turning after the "commercial jet fuel" smoke was turned off, completing the U turns even more to where they were almost going in a circle pattern. Someone forgot to read the "keep it straight and intermittent" memo that day.
