Controling creating and using the radiant flux
Started by indigo22, January 28, 2018, 12:03:54 AM
sm0ky2
Sodium chloride mixed with
copper, zinc, iron, chromium, and lead salts
These six main salts make up 99+% of this mineral salt
Quite contrary to the "84" the company claims on their packaging.
indigo22
thanks i'm making some new gans now just poored in some chlorine, see if i can get more then 0.6 per cell
for the container of the batterie i studyed the periodic chards and mylar seems the best
sm0ky2
To be clear, I am not saying that "ganz" is not useful.
But that there is no magical property of the substance
Other than its use as an electrolyte with a specific dielectric constant.
The Salt alone only has these specific properties in aqueous solution,
with a specific amount of water.
But The electricity comes from the salt and the other metals.
Not from the ganz.
indigo22
as a member off FESIG i highly recomment to visit our site and then you might be open to suggest you might be wrong
http://truevisionofpeace.com/FESIG.html
my intervieuw: https://youtu.be/OE7ssDmzUuw
indigo22
the best way to get radiant energy is to put a strong dipole from the primairie on a ground of the 2nd
then use a diode and collect the radiant into the plus of the 2nd
voltage of bias is more important then the amperage going trought it, sow you only connect the plus not the minus sow there is no amerage and heat loss, then pulse that dipole with a pwm and you got it
