DESTROYING Energy
Started by EHT, January 28, 2018, 03:06:03 PM
gravityblock
Quote from: EHT on February 03, 2018, 12:25:42 AM
The confusion here is that momentum is not a conserved quantity in this example. Momentum is mass x velocity and NOT the same as energy. You cannot transfer momentum and expect the same energy because they have different equations.
IF a 100% transfer of energy between the masses were to be effected, then it would result in the 1kg mass having a velocity of sqrt(5) m/sec - approx 2.236 m/sec
Mass 1kg. Energy=2.5J
V=sqrt(2E/m)
=sqrt(2 x 2.5/1)
=sqrt(5)
=2.236 m/sec
E=(mv*2)/2
= 1 x sqrt(5)^2/2
=5/2
=2.5J
Ask any "top physicist" (or just a "normal" physicist, for that matter) and they will tell you the same.
The 1kg mass moving at 5 m/s has 12.5J and not 2.5J as you have falsely asserted above!  More false assertions by you!
If a 100% transfer of momentum between the masses were to be effected, then it would result in the 1kg mass having a velocity of sqrt(25) m/sec - 5 m/sec and not the sqrt(5) m/sec - approx 2.236 m/sec as you have falsely asserted!
Mass 1kg. Energy=12.5J
V=sqrt(2E/m)
=sqrt(2 x 12.5/1)
=sqrt(25)
=5 m/sec
E=(mv*2)/2
= 1 x sqrt(25)^2/2
=25/2
=12.5J
One false assertion after another from EHT!
Gravock
gravityblock
Quote from: EHT on February 03, 2018, 02:48:49 PM
Firstly, I have made no claims. Secondly, even if I did decide to do so, I would not need any of your "support", thank you.
Lastly, all the relevant math was in my rebuttal. If you want to argue, show me where it is wrong.
Your math, based on false assertions, is shown to be wrong in my previous post (reply #48)
Yes, I agree that you do not need any support in making false assertions and in misleading and misdirecting the reader!
Case Closed!
Gravock
sm0ky2
kg * m / s
kg * m^2 / s^2
think more slowly
gravityblock
Quote from: sm0ky2 on February 04, 2018, 06:03:08 AM
kg * m / s
kg * m^2 / s^2
think more slowly
Time should play the part instead of meters or distance. We should look upon Time as the result of the force that impels a body through space. The greater the force, the shorter the time, and the shorter also the space to be traversed. Thus, if the force were infinitely great, time and space would be infinitely small, they would cease to exist. If the force was infinitely small, time and space would be infinitely great. But, again the force is not everything, because in reality it does not exist. All that exists is the impulse that is applied to the body in space and imparts momentum to it. The body's movement is then only limited by the resistance it has to overcome. What does exist then is the momentum that arises from the impulse of the force, and not the force itself.
The shortest distance between two points is a straight line, and the shortest Time between two points is a curved path!  Mass travels faster on a curve than it does a straight line.  In reality, it's a rectilinear motion through space.  All that exists is the impulse that is applied to the body in space and imparts momentum to it.   The impulse is the product of the force and the time for which it is applied .  Without motion, then there is no Time for the force to impart momentum to it.  Without Time, then there is no force to impart momentum to an object, thus there would be no motion.
The centrifugal force is described by classical mechanics as being a fictitious or fake inertial force.  The Coriolis force is also described by classical mechanics as being a fictitious force.  The Euler force is once again described by classical mechanics as being a fictitious force.  Together, these three fictitious forces are necessary for the formulation of correct equations of motion in a rotating reference frame.  Without these three fictitious forces, classical mechanics can't properly describe motion in a rotating reference frame.  Physics also speaks of virtual photons, etc.  Below is a snapshot at wiki on the "Fictitious Forces".  Both classical mechanics and quantum mechanics can't properly describe this universe as being real without fictitious forces, virtual photons, etc.  There is only one thing in this universe that is real, and that is Spirit/Consciousness!  Everything else is an illusion!  The Copenhagen interpretation of quantum mechanics is based on what appears to be the same nutbar logic as classical mechanics (fictitious or virtual forces, virtual particles, etc).  Once we realize science has nothing to bring forth that is real, then we can move onto the next level of technological advances.
Think outside of your little deceitful box, which is scientism ( a science falsely so-called)!
Gravock
sm0ky2
The momentum does not have the second unit of time
Because momentum is a relative term.
We require the other relation to determine energy.
It is not energy, it holds no energy, and cannot
Until you interact with it from another relative reference.
If I move at the same velocity as your Kg
It has no momentum.
In fact it has no velocity
We are both standing still
When your Kg impacts something, Then there is energy
Because you do not have one velocity, but Two
m/s * m/s = m^2/s=2
The velocity of your Kg, and the velocity of what it hit.
This is a relative term.
you did not "impart energy into your Kg"
but rather you increased the Kg's relative velocity with
respect to your inertial reference.
Which equates to a Kinetic Energy potential, to your reference.
The energy you put into it to change the velocity
is also respective of your reference.
Change the reference, change the energy
Because the relative velocity has changed.
You can do this without making any changes to the Kg.
If your Kg is standing still
and the Earth moves towards it at 1000m/s
it will have the same momentum as if the Kg were moving
1000m/s and the Earth stood still.
without a stationary inertial frame, we don't know the true
velocity of anything.
only it's movement relative to our own.
Momentum by itself, cannot be related to Energy.
you need the other factor.
