V Gate experiment using a Ring Magnet
Started by vineet_kiran, January 30, 2018, 07:56:59 AM
Belfior
it is a waste of time to debate with a believer. For both of them.
blueplanet
What you are talking about is the closed circuit theory taught in high schools. What is missing in the ordinary closed circuit circuit theory is the electrostatic waves or magnetic waves which can self-loop around the wire or over a surface. With this in mind, the energy can propagate without an opposite charges in the receiving end. For this reason, it is impossible to predict the behavior of open-ended conductor using conventional SPICE-like simulator or the like.
Open-ended transmission line has nothing to do with your theory. It has nothing to do with conventional resonance concept either. I am sorry about that.
Quote from: F6FLT on November 13, 2018, 10:51:44 AM"There is no "open-ended conductor", except in the minds of people who are not familiar with physics and electronics.
Any charge in a conductor remotely influences the charges of other conductors in the surroundings, even the orbital electrons of the atoms of any material, including insulators.
Any movement of charges at the end of an apparently "open-ended" conductor is accompanied by a redistribution of surrounding charges everywhere around it, which is equivalent to a current flowing from the "open-ended" conductor to other conductors through air or vacuum, exactly as through the dielectric of a capacitor. It is named "displacement current". A conductor is never really "open", it is always capacitively coupled to its surroundings. It's easy to verify: the hand near the open end of a tuned circuit changes the resonance frequency because it changes the (low) coupling capacity.
Did you at least conduct the experiment and the measurements?!
That's what I did.  And I measured that current is drawn from the generator when the LEDs are lit remotely from an apparently open end of a coil.
It is well-known electronics.  This is a problem for RF engineers because they often have to shield circuits that, although separate, are capacitively coupled (without real capacitor) to remote areas of high potential in the same equipment.
There is no capacitor monopole. For instance a single spherical conductor has really a capacity. But this capacity is calculated as this of a spherical capacitor with two concentric electrode ( C= 4*π*Ɛ0*R1*R2/(R1-R2) ), one being located at infinity therefore C reduces to C = 4*π*Ɛ0*R when R2->∞. In real life, the second electrode is not at infinity but is the surroundings as explained.
The universe is neutral and any change in the distribution of charges somewhere leads to a redistribution of all other charges by minimizing the potential energy.
blueplanet
Also, if there is any measurable current, your meter must have problems.
citfta
To the uneducated, everything seems like magic.  So they make up mystical explanations for what they don't understand.
blueplanet
Who is to blamed?
Me, Marconi, Tesla, Guobau or our high school teachers?
