user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
MrMag
Otto,
We all have to start somewhere. Thank-you for the update and good luck!
Tim
CTG Labs
FROM OTTO:
Hello all,
Dave please post this on overunity.com because this is the basic understanding what we are doing. Thanks a lot.
In the picture you see a wave. Its not nice but a wave. A kick is a wave too. A quicky but a wave.
I will take water as an example. The question is: in what case can a wave exist?Huh?
The speed F1 of the wave MUST be greater then the speed F2 of the environment of this wave.
Ok, now the guys of you with colledge degrees will wright 1000 words, and the end result??? You have it.
Now let us look what will happen if this F1 and F2 speeds are the same. There cant be a wave!!!
otto
Hoppy
Its like a transformer - pull more current from the secondary, loose voltage from the secondary and pull more current from the primary. Can't have more power from secondary without more input to primary. Basic induction theory.
Prove by this experiment: wind a 1:1 bifilar coil using around 1mm ECW on a 2" x 2" spool - fill to rim of spool. Use an iron bolt as a core for the spool. Using an 8 amp or higher 12V or 24V DC PSU, pulse the primary with your 555 oscillator at say 500Hz. Measure the open circuit output voltage across a high voltage polarised cap connected directly across the secondary in series with a high voltage diode. Now put a 40 or 60W lamp directly across the secondary and pump up the input pulse current until the light glows and then measure the voltage across the lamp and the current through the lamp. Note the substantial heat build-up in the iron core by eddy currents.
You will see from this experiment that as the TPU is currently configured and built, it is a just a complicated and inneficient transformer.
aether22
Otto, I'm not too sure what you think you have found, it would be nice if you'd tell us, but if you don't have the answer as to how you can induce a net dc voltage in a wire, then I don't think you have the answer to how SM get's is power.
Inducing a net DC voltage in a closed wire is impossible by any conventional means.
otto
Hello all,
again me. Ok if Im "Killing" your nerves I can be quiet. No problem.
Guys, you have always to ask WHY, and HOW. Like a little child.
I have another question: Its about the rotational magnetic field. Why do we need it??WHY??
We could make a coil or more or something and maybe get something out of this coils that would be maybe OU. I dont know.
Another thing: please dont look at me as Im your teacher. IM NOT!!!!
The only teacher here is Mr.Mannix and Mr.Steven Mark!! Not me. This is the cause for calling them "Mr.".
As Im only a human you will from time to time reed maybe crap from me. Ok, then please dont spit me. We are here to discuss.
Im only a little guy from a little country that wants to help you and of course me. I have no colledge degree, my english is a disaster but Im here. As I always say we are in the same "boat" and we have to make this wonderful invention to work.
Otto
