user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
wattsup
@gk
Check large9.jpg. Those wires go to the front of the unit where you connect the load. No wire or wires are leading off the base.
@all
Check large3.jpg. Is this baling wire core with two terminals exiting top?
I'd say the core was 1/2" thick by 4" high
Check large12.jpg with fuses. Are they going to the core baling wires?
Check the induction coils. Smack dab in the middle of the magnetic field.
Check the caps. Why so few caps? Why these caps? Where are they connected?
Caps make me think of start cap/run cap. Or it could be one cap per coil pair, two or three coil pairs.
Check the wires comming out of the bottom of the unit going to the center plastic box then going upwards through the induction coils then back to the top of the TPU. Is this the loop? Or is it reversed?
Sorry for so many photos but I thought you guys should have this.
gotoluc
Parts taken from February 14, 2006, SM to Lindsay
create several frequencies within the collector coil's circumference. The frequencies are directly related to the circumference of the collector coil. You can begin to collect the current and dissipate it with no need for amplification because the signal source also becomes the feed for the power source and has the natural tendency to run with gain. Important, you can never tune too closely to the exact frequencies of power conversion because the power received by the collector will instantly destroy it. We must deliberately tune little off the conversion frequencies in order to make it properly work. That is why the control units are so important. Without the control unit constantly monitoring the frequencies of operation and making the necessary changes to keep the whole thing off exact conversion frequency, then the unit would very quickly destroy it's self.
These directions from SM, are they being used in your tests???
rensseak
hello to all,
when i saw the short spikes on the scope from GK i was thinking why we are not use it for ultrafast switching, if it is possible.
just my two cents
norbert
AhuraMazda
Quote from: otto on January 10, 2007, 01:22:16 AM
maybe something important maybe not.
Otto,
Any unusual behavior is important because we are not working with n exact science and are still discovering.
Please can you send pictures and drawing of your new coil. I know you can not post pictures here. Do it the usual way.
By the way, I had problems with accessing files when I first started using this site. I upgraded to firefox2 and the problems went away.
AM
