user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
giantkiller
Eugene Mallove, Paul E. Brown.
Google: 100 dead scientists to get a comprehensive list of what the possibilities are should one try to do what's right in the publics eye.
That is what I did first and now I am here.
Movies you should see are Enron, 911inplanesight, and follow the trail of data from Waco to OKcity to Building 7 @911 to Enron to Sharwzennegger to Bush to Iraq. This is what goes on should you choose good or evil.
--giantkiller. To not believe is to fail.
Yamanashi Jr
Is it merely a base or does it have something to do with the magnetic fields?
Gearhead
Hi,
I do believe that. Top and bottom, magnet in the middle.
I like the idea of a tank circuit cap+coil just tune right freq. and make it ressonante.
The other thing is that Tesla made a coil that didn't needed caps because it would go back and forward, with capacitance in the same coil windings. It would have a double windding from the end to beginning again twice. I never tried that. The speed might be the 5K but it might oscilate for the starting process. 'just keep whatching. :-*
Check the Waveguides by Tony R. Kuphaldt (he's great and knows a lot)
http://www.ibiblio.org/obp/electricCircuits/AC/AC_14.html#xtocid250917
When the party is over
... I just keep dancing to the rhythm
tomas
since it speeds up, maybe it is using some sort of "self triggering"
for example a pulse is fired in control coil one, which triggers a fet which discarges a charged capacitor into control coil two,when this happens another fet triggers and discharges another capacitor in control coil three, and again this triggers coil one repeating the process,speeding up untill the maximum speed is reached, firing capacitors simultanly into a coil could create rotation and the radiant energy effect which at those speeds supercharge the collectors.
the diagram needs some changes in allowing one fet to be active at a time, this drawing is only to give a simple idea of what i mean, also maybe additional hardware is needed to keep the speed/frequency at certain points so it stay's there.
*offcource this method would mean the frequencys are directly related to the coils circumference,  as the coils get bigger the frequency goes down.
*also it matches the exploding television if the tubes were close to the yoke, this self triggering could occur.
*certainly matches the firing of cannons.
*it matches variable tuning devices.
*it will turn a compass violently, starting up slowly,in a pulsed fashion.
*it represents the turbine effect.
*The multiple frequencies begin to feed themselves.
*takes just a few seconds for the coil to begin to function at maximum effort.
*Rotation of field. . .
*when magnets are used to trigger the fet's, the field would speed up and start to resonate with the field of the magnet in a feedback like fashion (input vs output).
T.
pese
The "idea" sounds good ..
but Condensors cant discharge via the gates to the coils.
(fault in scematic)
Pese
tomas
again, the diagram needs some changes , this drawing is only to give a simple idea of what i mean.
