user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
starcruiser
@Grumpy,
Thanks for the link, very interesting. I see many parallels here. humm....
Gotta try something.
Regards,
Carl
Grumpy
        -Frank Edwards
Victor
devrimogun
Quote from: giantkiller on January 19, 2007, 02:20:24 PM
http://www.icehouse.net/john34/bedinibearden.html
The other kids liked it; that's how it was voted 'best of show'. Adult judges gave her the other top prizes.
She flicks the wheel, into motion and it runs.
"This is the electromagnet coil (TPU kicks?). It has the power wire and the trigger wire... The power wire carries the voltage around the electromagnet coil and it goes through to the transistor?that little black thing?then it goes through the resistor and the diode and the trigger wire follows it and then the voltage flow comes out again and returns back to the negative side of the battery... The electromagnet generates the power, then it spins the wheel; the electricity goes through the generator coil which lights up the light-emitting diode. Then it starts all over again."
"We've been using this battery for a month or so now. It's supposed to have only 900 spins per nine volts, and that's a nine-volt battery, so if it were to run out then it would have run out a long time ago!"
She has only changed the battery three times since building it six months ago.
Thanks for bringing up Bearden and Bedini. Does any of you have any comments about the recent book from Bedini and Bearden titled "Free Energy Generation Circuits & Schematics"
On a WEB site I came accross to a simple circuit and an explanation of incredible nature for it. I will attach the circuit and copy the explanation below.
My question is : Do you think the circuit attached can work? Or is it a hoax like some skeptics say.
Explanation : Here is one of John and Tom's patented inventions:
This is a circuit for capturing zero-point energy.  There are no moving parts and only one simple coil needs to be wound since all of the other parts are readily available electronics components.  The circuit operates by charging a  capacitor to a high voltage and then discharging it suddenly.  This sudden discharge creates conditions where the local environment feeds large amounts of free energy into the circuit.  This energy is "cold" electricity or "negative" electricity  and it acts in the opposite way to our everyday "hot" electricity.  Items such as resistors, transformers, coils, etc. which cause losses in a circuit driven by "hot" electricity, act in  exactly the reverse way for "cold" electricity and actually  gather additional energy into the circuit from the surrounding environment.  It would not be unusual for the circuit shown below to have an input of just 200 milliamps and yet generate an output %%[Page: 1]%%
power of 300 kilowatts.  The overall strategy is to have the circuit powered by a battery, and arrange for the circuit to charge a bank of batteries which can then be used to drive equipment and power other loads.  A circuit of this type can  reasonably be expected to have a COP (Coefficient of Performance, i.e. Power Out / Power In) of anything from 20 to 100.
The rate of charging of the output batteries increases gradually over a period of a week or so, and eventually the batteries should be charged about 50 times faster than is possible with conventional "hot" electricity.  The circuit looks  very simple, and indeed it is simple to build, but do not be fooled into thinking that it is a normal circuit - it isn't.  Thiscircuit is designed to capture external energy and its design is based on an understanding of exactly what the zeropoint energy field is, how it operates, and how to capture it.  This circuit can run continuously day and night.  In fact, it actually operates slightly better at night, due to reduced interference from other energy sources.  Here is the circuit:
There are no moving parts in this circuit.  The key component is the transformer which is a simple coil wound on a laminated iron-cored former.  It is wound with three separate  wires at the same time.  This method of winding is called  "Tri-Filar" and this particular coil is made with 450 turns of No 23 AWG wire (0.511 mm diameter conductor, equivalent to 25 SWG as shown in the table below).  The coil is wound with the three strands simultaneously, so that each  winding is exactly like each of the other two windings.  The circuit operation is as follows:
This section oscillate, generating an alternating signal in each of the three windings.  For clarity, the winding shown on the left looks shorter than the other winding, but in actual fact, each coil has 450 turns.  When the On/Off switch is  closed, powering up the circuit, this section gets kicked into oscillation, and it continues to oscillate as long as power is applied to the circuit.  A device like this tri-filar coil acts as  a collector (and effectively, an amplifier) of "cold" electr icity  drawn in from the surrounding environment.  This energy is passed through to the third winding: %%[Page: 2]%%
The power arriving in the third winding shown here, id rectified by a "bridge" of four diodes, each rated for operation at 1000 volts.  Although the battery powering this circuit is a 12 volt battery, the voltage coming out of the third winding  can easily be 300 volts.  This power is fed into the capacitor, whose value should be in the 1 to 10 microfarad range.  The capacitor voltage builds up with each successive pulse from the oscillator section, and then it is fed into the  batteries when the SCR (Silicon Controlled  Rectifier or "Thyristor") is switched  on suddenly by the transistor.  Both the capacitor and the batteries also act as collectors of "cold" electricity when operating in this circuit.  However, the energy  ends up as "hot" electricity inside the battery, and each charged battery can be used to power equipment in the normal way.  For example, the battery can power a standard inve rter which will supply mains  voltage sinewave power to  televisions, DVD recorders, computers, etc.  An important point to notice, is that this section of the circuit is "floating".  In other words, it is not grounded or earthed like the earlier section of the circuit.  The voltage being developed in the  capacitor is relative to the charging batteries and nothing else.  This is an important feature for the gathering of free energy from the environment.
The last section of the circuit is the timer which is used to switch on the SCR to feed power to the batteries:
The 555 timer chip is wired completely norm ally as a slow-running oscillator.  It is in a standard "hot" electricity circuit which is grounded.  For that reason, the output of the 555 chip on Pin 3, is fed to an opto-isolator, which keeps the two  circuits completely separate.  The 555 chip just switches the 2N3584 transistor hard on, which in turn, triggers the SCR into it's ON state, where it stays until the power in the capacitor has been transferred to the batteries as a massive  pulse.  When the voltage on the capacitor drops far enough, it starves the SCR of current, which causes the SCR to turn OFF, where it stays until triggered again by the 555 chip.
There is a good deal more information on this and other important circuits in the book by John Bedini and Tom Bearden and I encourage you again to buy a copy and study it carefully as it contains very important information giving  a clear insight into how the universe actually operates and how you personally can benefit from the knowledge.
