user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
hartiberlin
Quote from: giantkiller on January 29, 2007, 12:04:48 PM
Quote from: rotorhead on January 29, 2007, 10:02:08 AM
Quote from: Yamanashi Jr on January 28, 2007, 07:25:43 PM
I just posted a cross reference here about Alfred Hubbard GENERATOR:
http://forum.ctglabs.com/index.php?topic=40.15
Maybe someone can repost the information here for those of us that are not members on ctglabs.
Thanks
http://atl2.netfirms.com/engy/mutch/matrixlaw/hubbard.htm
http://rexresearch.com/hubbard/hubbard.htm
http://amasci.com/freenrg/hubbard1.txt
http://www.linux-host.org/energy/shubbard.html
http://www.overunity.com/index.php/topic,1761.1450.html
http://www.zpenergy.com/modules.php?name=News&file=article&sid=2206
Now its over here!
--giantkiller. To serve is the greatest reward!
As can be seen from here:
http://rexresearch.com/hubbard/hubbard.htm#usp1
Hubbard had used radium to enhance spark plugs,
so I now know, that he also used this technology in his coils
if he used spark gap contacts coated with radium the coils
get much more oscillation from the excited radioactive decay.
The same way worked the Morray device, just as a negative
resistor through excited radioactive decay in his radioactively
doped tubes ( diodes),
where the contact points were out of uranium doped materials.
Radiactive doped diodes can work as real negative resistors,
if RF bursts are applied.
The energy is extracted from the excited beta decay, which are
free electrons, which are added to the electrical circuit from the
radioactive decay. So it works as a real negative resistor= passive amplifier
without batteries !
Regards, Stefan.
otto
Hello Marcel,
yes, I need money but I will NOT SELL MYSELF!!!!
This TPU is from Steven Mark and Im only a little guy working very hard on my TPU and thats all!!!
Otto
aki21
HI, Im new in this forum, and new on this type projects, im so darn curious!! can i ask for parts/components? coz i cant catch up on those beatings..... about the Magnet, could i use a speaker magnet for these?? sorry for being dumb, need some alot of info 1st. thnx
libra_spirit
Quote from: CTG Labs on January 06, 2007, 06:21:36 AM
Perhaps I wasn't clear!
I agree with what you are saying, like phase motors, the TPU doesnt have a real rotating field.  You can only get that by rotating a real magnet!
All we are doing is turning certain coils on and off at different times and compass can ride this effect making it appear to have a rotating field, but thats just a visual illusion.
So, I am not sure how this gyroscopic effect can appear, something unknown must be going on, which can only be a good sign?!
D.
On rotating magnetic fields and mass rotation:
I believe you are missing a valuble quality of the nature of Copper which may shed light on this concept. The major weight of the copper atom lies in the nucleus. The nucleus of a copper atom is magnetic, but its electron shell is not magnetic but electric.
If you place copper in a rotating magnetic field one of two outcomes will happen. The copper will be physically dragged along with the moving magnetic field, or if the angle intersects wire at 90 degrees you will produce an electric flow. You get torsion or EM and the two are not the same.
The mass of the copper can thus be rotated without physically moving the copper device at the electron or matter bonding point.
As the moving magnetic field intersects a wire at 90 degrees the familiar kick will emerge. If you stretch this pulse out on your scope you will notice it is a series of sine waves at the NMR frequency. Maybe about 6 sine pulses at approximastly 5 Mhz.
Copper will act like a magnet at the Proton layer and it will follow a moving magnetic field, precessing around the polar alignment. These NMR pulses were discovered in the 50's by a nobel prize winner, and then abruptly forgotten, where down to now we still believe the myth that induction and diamagnetic fields happen only on the electron shell. Not true, the Proton is very much involved in this process.
Because the Proton will lag the turn of the magnetic field due to its higher mass we get a dragging effect from that layer that pulls the electron shell into a negative or dragged state. Induction lags in time frame, and the NMR rate is the factor by which it lags.
The TPU would seem to be turning the magnetic field in the copper atoms, using 90 degree pulsing coils. To make it turn completely over takes only a syncronized pulsing scheme. The magnetic field will rotate its poles through the collector wire loop. As the poles cross the wire no current will flow and energy will move into the torsion field, as the magnetic field moves past the 90 degree angle with the collector wire the energy will shoot into the electric field and the series of very high pulses will be shot down the wire as it crosses.
The TPU is embedded in cork to stop it from vibrating to pieces. Each time the magnetic field moves between the torsion state and the Electric state it creates a small jerk and makes a physical motion of the wires.
The TPU exhibits an inertial momentum, or gyro effect because its Proton layer is in a spinning motion of its magnetic poles, this creates a "forced precession". Best guess.
The entire mass of the copper is in rotation at the nucleus, this is one quality of copper making it an AG metal.
Dave L
supersam
Quote from: libra_spirit on March 28, 2007, 09:43:15 PM
D.
Dave L
