user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
raburgeson
It's likely 50 watts or higher, 40 watt down are weak filimented and off frequency operation would probably kill it quickly. Thin filiments vibrate like crazy, if you break open a burnt out bulb and look at the flare assembly, the leads (heavier are the power and ground) and there are 2 or three braces on the top of the mount, They are attached by what is called the "button". That's the heated and mashed rivit head on top. The braces are a speacially figured spaces apart to support the filiment at a point were the vibrations don't meet. I know I'm boring you but I think 50 or 60 is a good guess by whoever made it. If it's lower the person lighting it is going to go through a lot of them and be rather unsuccessful at demos.
Thank you Dom, I'm glad you said that , we don't even know if it's in the group , big money big trouble, but that was approap. I said way to much the last time this happened and I'm glad Stefan understood why I got grumpy but, I didn't want to do it twice.
I still think the heat in this unit provides free electrons to the TPU like the heater in a magnetron provides electrons. wonder if this is right. Did you note what freedomfuel said about not going out of round, and then I see a post about an ovoid shaped coil, confusing.
mrd10
Yes Dave was doing alot experiments, and he is the one that came up with the three transformers, that is feeding in into two and outputting to the 3rd, his been always asking how do you measure these kicks, he wasn't happy until he could test this phenomenon.
I was just going back through the other thread and his nick i think was ctglabs, but i see ive responded to him at post 56 but he isnt listed....why?
whats happened to his posts? Stephan do you know?
A guy that spends many years of his life researching FE aint going to bs, trust me on that one.
Cheers,
Dom
xilusma
HI All,
Just wanna to say about the X's TPU, I've read some where, that he mentioned inside of his device doesn't have any iron core or anything else except for air core. How's the configuration, he did also mentioned to check back his last experiment on the spinning compass. Do any body still have the copy of his tread on the subject?
And the TPU doesn't acted like normal transfomer as normal transfomer do.
From his information, he did also mentioned about frequency/s being feed into the TPU.
My personal opinion is that the TPU is used as "grooming" area for the frequency/s before the anomalous frequency effect occurs (mixing of the 3 frequencies).
He did also mentioned that his current device is not OU yet, as the power source for the feeding is still need to be sourced from outside.
For tought, can the earth reasonant (7.8Hz) be used in one of the frequency for the TPU?
Regards,
p/s : nothing much to say
use energy wisely - dare to dream
raburgeson
thinking if it resonates at a frequency and like an antenna and is already immersed in the frequency, it may be an input that doesn't require a physical connection. And then I'm full of gas and have no idea.
If everybody tries to answer though we may come up with something.
come on somebody else try.
AhuraMazda
Please correct me someone if I'm wrong. X said his device is not OU. In my opinion A TPU is not an OU device. It is an energy trap. A bit like the sails on a ship.
AM
