user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
MrMag
All I can say is WOW. Dave sure has a lot of patience. I didn't bother counting how many times he said "don't worry about the coils" and "mixing 3 frequencies" but maybe it needs to be mentioned here a few more times. We have already seen pictures of the coils and how they are set up. Now we need to do a little homework and build some coils, hook them up in different combinations, and mix in some frequencies. Hopefully we will then see what Dave is talking about. After this point, we can then start to worry about how to wind the coils properly to hopefully be self resonant. Personally, I feel that the coils should be wound to certain resonant frequencies of a magnetic field. But until I do my own experimenting my comment is probably a little premature.
Before anyone posts anymore question to Dave, I strongly recommend going back in this thread and read all of his posts. It seems that he is not sure exactly how and why this device is doing what it is doing. It is impossible for him to answer some of the questions that are coming his way. Maybe one of us will come up with a combination that Dave never tried. He has fed us with more information in the last couple of weeks than we have seen in what, 20 years?
Let's get building people!
In the meantime, I would appreciate any additional information that Dave can give.
Thanx again Dave.
Tim
hartiberlin
Quote from: AhuraMazda on December 05, 2006, 02:21:05 PM
Stefan,
Thanks for clarifying the coils issue. I also think your idea in your second drawing is good. But, are you proposing 2 different approaches or are you suggesting these coils will be placed on top of one another? The reason for  my cofusion is that you have output coil in both drawings.
Grus
AM
Hi AM,
these are 2 different methods...
The first drawing was just the test method, what Dave told us:
1. Just One collector output coil wrapped with 3 coils to test the 3 different frequencies
mixes to see this strange DC pulse superposition.
The second drawing was my idea, how these fields repell, if you use
3 x 2 partial coils as Dave has done in his TPUs...
I don?t know, if he has connected them in this repelling way,
so that the flux goes out into the center and rotates there,
but this I could imagine could be the principle to rotate the compass
inside the center...
Also this would give induction inside the last 22nd coil, which is
wound around the whole stack !
Hope this helps to understand my ideas..
Regards, Stefan.
starcruiser
@MrMag,
I am thinking you are correct in your comment regarding "tuned" coils. I also think ...er X is correct in the 3 frequencies also. taking these points into consideration then if the coils are tuned to naturally resonate at a certain frequency or harmonic there of we should see increased power generation.
I was thinking the tuned coil direction for several months and have been checking the inductance of the coils I wind. My latest TPU v4 will get the same treatment. Checking the inductance and calculating the natural resonance, then sweeping the coils to see where they sit at in terms of resonance.
I also check the inter coil capacitance. I'd suggest all do the same when making your TPU's and record this info so you can share this info  and document the correct coil configuration and recreate the environment when you hit the magic frequencies and the TPU sings.
Regards,
Carl
dean_mcgowan
Stefan,
Challenge accepted, will post when I have some substantiable results, I will refrain from posting what does not work and any guesstimates. Might do well for others to do the same instead of creating misleading and unsubstantiable threads. Maybe this thread should be moved into a more appropriate section  .. like
"good ideas that have yet to achieve any repeatable results"
or maybe
"scams that went south with their unapoligetic instigators"
nuf said ..
I wont disturb this section of the forum anymore .. you have my word.
And should I be successful in creating overunity or free energy .. I will create a thread with the appropriate information and title that will not degrade the value of all other posters such as this has.
Regards,
Dean McGowan
starcruiser
I had forgot to mention, when you wind your coils and if you check the collector with your scope before you put your control coils on them, you will see no signal, however after applying your control coils, and they are not connected to anything, scope the collector again, you will/might be surprised.
note: the scope voltage setting will need to be set to the highest sensitivity.
Regards,
Carl
