user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
otto
Hello all,
Stefan,
Im with you every day (logged in) and looking what you are doing. Im in big work with my TPUs. Winding, testing looking to the right frequencies...
Otto
hartiberlin
Hi All,
yeasterday I used  2 frequency generators and one radio for my 3 coils, cause I could not find my 3rd frequency generator...
but I never got my LED to light brighter, than the power already put in from the frequency generators...
I also did not see this strange DC pulses that Dave spoke off..
The maximum transfer of energy from the control coils to the collector coil takes place, when I have a cap parallel with the output coil
and when I hit the resonance frequency of the collector coil -cap LC tank... I guess I must try it with 3 * 2 partial coils, so the flux goes out into the center and really can rotate....
hartiberlin
@Dave,
did you fire up yet your new big TPU ?
@Otto,
kannst Du mal ein Schaltbild posten, wie Dein Rodin coil TPU aussieht, wo Du 2,25 Watt mehr rausbekommst mit der bifilaren Spule, danke.
English: Can you please post your TPU circuit diagram, where you can get 2,25 Watts more out than in ? Thanks.
CTG Labs
Stefan,
I have not fired up yet, I did not feel well today and I have to drag myself out tonight to the work christmas party with my colleagues, but I would rather stay at home and work on the TPU, sad isnt it!
I want to fix it to a wooden base and make some terminals because there is 94 wires coming out of this TPU and many combinations that can be had.
Also I cannot get steady effects with my simple 3 way pulse generator I built and I am looking to buy 2 more proper generators to go with my existing one.
Will post more when I can.
Have you been able to see the waves starting to mix in the collector?  I have not used a cap, at this stage I recommend just looking at the waves mixing, not trying to measure the output power, just looking for the DC spikes with the right frequencys first, then you may start running  ;)
D.
hartiberlin
I did not get any strange or OU effects with my TPU yeasterday, BUT I think I found out, how to build a real interesting other device.
Maybe I should call something like Hartmann?s orthogonal magnet jump transformer or something simular. Later I will open up a new thread about it.
The principle is quite easy.
When you look again at this new bicycle light dynamo, where the magnet allways jumps and toggles inside a small box, where a coil is wound around it, you can see, that it jumps back and forth and generates power in a coil wound around the box-case.
Now I do the same, but for giving the magnet a kick, I wind another coil by 90 degrees onto the case and the case is always so positioned, that the magnet will always jump inside the case-box, when I apply a pulse to the 90 degrees driver coil. The magnet will always jump with the driver pulse and induce output also in the output coil, which is 90 degrees turned wound, so the both coils together do not work as a transformer and don?t influence each other ! You can also design it this way, that you place 2 case- boxes ontop each other, each with one magnet inside and each with a coil wound around their case. Then place the lower case 90 degrees to the top one and drive the top one with short pulses, so the magnet begins to jump inside the upper box. This will influence the lower magnet also to toggle and jump inside the lower box, which is 90 degrees rotated and this box will only get induction from its own toggling magnet inside. No influence from the driver pulse. It works really quite nicely as I tested yeasterday. Pics and videos later, wheI am back at my PC.
