user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
turbo
Quote from: hartiberlin on December 10, 2006, 01:24:27 AM
Seems to be quite some nice power level you can generate
from this small battery...
How long does the battery last ?
why does evreybody always think the power is comming from the battery?
you should know better.
IT IS IMPOSSIBLE TO LIGHT A 240 VOLT 75 WATT BULB OFF A 3 VOLT LITHIUM CELL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
IT WON'T EVEN FLASH A SECOND.
please try it, try it, try it.
the simple explenation:
a generator fires a pulse into a wire, the pulse travels to the end of the wire and reflects back.
when the reflected pulse is returning at the generator , the generator again fires a pulse, so if the system is properly tuned, (variable fine tuning recommended) the new pulse will add to the returning pulse and double, and take off again and again.
this process repeats and very high voltage is being generated between the coil and the sphere, which create waves.
if there is a wave present at the tunning frequency, these waves resonate and there will be an exchange of energy.
the battery is only there to get it into resonance with a source.....
i never knew there was so much "power" on so much "channels" around us.
basicly its like tuning a radio, the neon bulb is the speaker.
you can come across strong or weak signals.
the voltage multiplier is actually a verry special filter element.
it splits up some stuff in space conjunction , or so i believe.
and yes ,these are modified tesla coils.
the output is not realy measurable with the meters i have, and i don't want to blow up my scope.
Turbo
CTG Labs
I am moving on with testing and clearing some stuff out as I have ended up in room full of coils and TPUs.
The first UK based person to reply to this post gets this small test TPU in the post free for christmas.
You can then hook it up to your signal generators and play.
MERRY CHRISTMAS.
X
AhuraMazda
Dave,
me, me me! No seriously the group seems to have moved to a new project but I am still here!
I am UK based! So if your offer is real I'll email you my address.
AM
MeggerMan
Hi Turbo/Marco,
I have to say those dancing magnets are superb!
I have just got to do this experiment!
The 7.8 Hz. Schumann fundamental frequency is the key ehh.
QuoteThe Schumann Resonances are the result of cosmic energy build-up within the cavity that exists between Earth's highly conductive surface and the conducting layer in the upper atmosphere called the ionosphere.* This creates a world-wide lightning display of broadband electromagnetic impulses that fill this cavity and that act as the stimulus for the cavity to resonate.
* A part of Earth's upper atmosphere is ionized plasma caused by the sun's ultraviolet radiation.
This layer, the ionosphere, couples Earth's outer magnetosphere with Earth's inner neutral atmosphere.
The Schumann Resonances are a part of many frequencies that create Earth's "Harmonic Signature."
So what we need to aim for is to use two higher frequencies together that create a resonance at 7.83Hz and this drives the collector coil to draw atmospheric energy.
So it is basically its a very low frequency energy receiver?
I am baffled by how you have powered a 75 watt bulb using just one contact.
Does the screw thread of the Edison bulb form a kind of ground plane?
So if you touch the wire on the screw thread the power transferred through the bulb will be a lot less.
Every time I think that I have the right idea for a pulse circuit I read a bit more then suddenly realise that its no good.
There is talk of divide by N chips, phase lock loop circuits, VCO oscillators etc.
Does the start pulse for each frequency need to be in sync?
Or can the frequencies run freely as long as there is a harmonic of 7.83Hz?
Could you post a sketch of your circuit diagram so I can take a closer look on how you get the feedback loop working.
Rob
stevewal2
AhuraMazda, you beat me there, haha. Good luck with your testing,
Steve.
