user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 58 Guests are viewing this topic.
starcruiser
From my observation otto is switching at the negative end of the circuit, something that Tesla did to improve the radiant discharge.
Regards,
Carl
starcruiser
Regards,
Carl
aether22
Otto, the two collector control pairs should be connected to each other (at both ends) and nothing else.
So both ends of the top controller coil should connect to both ends on the mid collector coil, and no other connections should be made so these two are unpowered and isolated electrically, power other controller coils in these two rings. (and same goes for the other pair)
I'm not quite sure if you'd consider that to be series or parallel, I'd say series but the point is each one is not connected to anything else.
BTW try reversing the connections too as there is a 50% chance you'll get it the right way and I'm not even sure what the right way is yet. (the aether inductances must add)
note: As I understand it, Litz wire isn't any bunch of wires, it is only when the wires are insulated from each other, you can get wire with hundreds of insulated cores it in, normal multicore wire is not litz.
pese
When Litz wire , mean the german word "Litze" than ist is only
uninsulated core wire , that is produced , for RF Applications
aswell for "flexibel" (general purpose) wires . (instead  singel wires that is not not
for mobil (moving) use as : power-cords etc.
I am not shure that the engl. "litz" is another product !
Pese
aether22
Oh yeah, and Otto (or ANYONE else here) do you find gyroscopic or other resistance to motion or vibration from your coils?
Because that would be pretty impressive!
