0 Members and 63 Guests are viewing this topic.
Russell Lee
Quote from: Rhead100 on September 20, 2009, 08:33:33 PM
Hi Russell;;;   I really like the way you put that.
"This new design is basically the ancient one with a twist-the pendulum, which means nothing but that it is a variant of the original."
Like the F-!4  Tom-cat is basically the ancient one with a twist-  better aerodynamic design, Aluminum Alloys, and jets that can produce many more pounds of throust per pound of engne weight.instead of the old prop planes.
I am with you all the way Buddy.  There is nothing new on this earth.  Only improvements to old ideas.
Purly for the sack of discution.  Let us say. The machine does not put out more energy than is put in.  AND, At the same time acknowlage the given Fact that it operates Exactly oposet of every other machine on this planet. In that the more resistance is put on the machine the easyer it is to operate.  Would this not mean that there is "A POSSABILATY"  that it just might, or could be,  THE most effeciant machine ever designed to this date.
I proposs ;;;;;    IF; it is possible. Then it is worth my time to look into. And any constructive sugjestions you could come up with would be welcomed with OPEN arms.
I honestly say to you. Your sugjestion that this may be an ancient design with a twist- the pendulum.   This thrills me to no end.  For IF, the pendulum is an improvement on the old design.  Then maybe we need to improve the penduluim next.  And seeing as the pendulum has been around for some time now.  Maybe it is time to think 'IMPROVEMENT" of the pendulum.  As I have stated in one of my videos. We have redesigned the pendulum to reduce air friction by over 95%. And when we can afford it ,  all bearings will be tefflon coated.
I tell you now with 100% knowlage (not thiory) anyone that is not sure of this machine or has second thoughts as to wether it works or not. Has not  operated one with his or her own hands.
I wil now formaly give an OPEN invatation to every one in this forum that has second thoughts as to this machine, to come to my home and try it out for yourself.
                       Raymond   RHead100
Easy brother, improvements to established designs is not in question.  The only reason I put up that message was to just bring out that this design has been around for centuries, and that in those centuries it has basically remained the same without improvement.
I truely hope you have the invention of the century on your hands, and that it changes mankind's estate.
  The F 14 flies just like the old one, but it still doesn't fly without fuel.  The Chinese Spoon-Tilt Hammer couldn't run forever by itself, by saying yours is overunity, your saying it will-big difference.  This is a major difference that, if correct, will change humanity, feed the hungry, bring energy to the world for medicine/food storage, and probably hundreds of other things.
  Skepticism is a requirement in engineering, it was important to let others know that this isn't a brand new thing, I do not doubt that it possibly could be made to work as you say, but up till now, nobody has been able to do it for centuries.
  Until it is running by itself and not just pumping water, it's difficult to believe it is overunity.  Closing the loop is the whole game, overunity does that.
                       I pray that you achieve this for all of us.
                                                          -Russ
Rhead100
Quote from: Russell Lee on September 21, 2009, 12:20:49 PM
                                                          -Russ
Thanks Russ;;  I had a feeling you were on my side.. Thanks .
I am just too close to stop now.
I am truely blessed to have friends like you and the others here Rooting for me.
       Raymond     RHEAD100
Xaverius
Great work Raymond!  You've made excellent progress since December when I last contacted you.  Your theory and ideas are sound so DON'T listen to any naysayers.  They will argue until the end of time that Free Energy isn't possible, but your videos prove differant.  Please keep up the positive attitude, a lot of us are pulling for you.  Naboo is right, watch your back, there are lots of losers out there that want you to fail.  Also, thanks for the reference to VanderWaals videos, I have been searching for several months for Lego clock/pendulum/mechanical mechanism videos for months, so you've saved me some effort.  Best of luck in Closing The Loop and please keep up the good work!
Merg
Quote from: Russell Lee on September 20, 2009, 05:13:15 PM
Before anyone gets too goo-goo about this machine I suggest they inspect the design of the ancient Chinese spoon-tilt hammer.  This new design is basically the ancient one with a twist-the pendulum, which means nothing but that it is a variant of the original.  It is also similar to other ancient machines like the Oliver (treadle hammer), and the Shadouf (Swape).
Maybe such pendulum machine with great efficiency existed many years ago... maybe the pyramids were built in that way... and now we forgot that technology... Even Milkovic doesn't discard such possibility:
http://www.veljkomilkovic.com/Images/Milkovic_Oscillator_in_Prehistoric_Times.jpg
Rhead100
Quote from: Xaverius on September 21, 2009, 02:30:51 PM
Thanks Xaverius ;   Glade I could help. And thanks for the incuragment.
As for the naysayers, those dumb asses would not know fee energy if it hit them in the ass with a board.  Energy IS free.  It's the dang machine that converts it ti useable energy that coasts money.  The wind blows free. But it does not make electicity nor does it grind corn.  Windmills convert it to useable power.
I have said many times,  the 2 stage oscillator does NOT make energy from nothing. AND it is not perpetual.  It will ,  like any wind mill, water damn or coal or gas fired boiler,   need maintanience.  Sombody is going to have to build it.  And somebody is going to have to maintain it.
Damn;;;  Aint life great.  Look at all the new jobs we just created.   OOOHH  shit;; I just used that Nasty,  7 letter word. (CREATED).  Hay;;  Before all you naysayers get all bent out of shape ,  I did not say from NOTHING.   HAHAHAHAHAHAHA.
                       Raymond   RHead100
