Nabo00o
We can hope that Milkovic used the proper measurement methods to obtain the results which he has given us, however, his results are not comparable with any of ours except if we replicate his construction close to a 100%. If they are not we end up with a completely different system, which can give both better or worse results. As is my belief, the real efficiency and COP of this system is entirely dependent on its Q factor.
The larger the amplitudes gets, no matter if it is a pendulum, a string, spring or even an LC tank, the energy output is entirely dependent on how high its amplitude can be increased through resonance before it is drained by the load.
Try to imagine other possible setups than just the classic pendulum. Some are better and some are worse. And some are really f****ng crazy insanely better then the pendulum...
Julian
Static energy...
Dynamic energy...
Two forms of the same.
Solomon111
On College of Enginering, Amravati is written Minor Project :  To decrease human effort in pumping of wather from hand pump by using a pendulum. The author based the work on HAND WATER PUMP WITH A Pendulum by Mr. Veljko Milkovic[. Pump by Mr. Milkovic is known throughout the world. Pump is studied at university, but has and good everyday use. And in India, this will be applied pump.
Work of this student is an attachment hence it can be attached to readily installed classic hand pump with very less modigications thus making it much more useful. This idea provides alleviation of work, becouse it is enough to move the pendulum occasionally instead of large swings.
http://www.veljkomilkovic.com/rucnaPumpaEng.html
Ken the Great
I see nothing special at all about this device.  Take a perfectly balanced wheel and give it a hard push to get it spinning. Just like he did with the pendulum, then give the wheel a small push every second or so, to keep it going, just like he did with the flashlight against the side of the pendulum.
Nothing special at all.
Solomon111
Good video, but I have a small suggestion: Black weight should be massive, because then it would  be much useful. But, certainly, it would  be better if this invention we connect with the invention of Mr. Veljko Milkovic.
http://www.youtube.com/watch?v=hNpgl7o_1QI
