0 Members and 25 Guests are viewing this topic.
tagor
Quote from: Cloxxki on May 23, 2010, 08:21:29 AM
The more Milkovic demonstrations I see, the more it comes across like gospel. Experiments are inconclusive due to disadvantaging traditional energy transtions with angles and overhead weight.
I experiment this for three years ... and ...
yes it is impossible to get good work with this stuff
MoRo
Sort of. I you run past a  pole, and let your extended hand engage it, you'll change direction without losing speed. And possibly strain your arm. The pole doesn't care, it wants to be left alone. In theory, EARTH is brought a bit out of alignment due to the change of direction. Would we take energy from Earth this way, or merely send it in a slightly different direction?
If two identical bouncing balls hit each other head-on at equal speed, they continue in opposite directions, same speeds again.
A brain teaser might be this one:
Two wheels are found to be of identical build, spinning at identical rpm, just an inverse of each other without slowing down. The nice thing about frictionless wheels...
This is such a unique find, it's decided to bring them together. The wheels engage side-to-side like lost soulmates, and...stop turning instantly. Was Energy used to slow them down? Was KE killed? Or was there never real movement?
Each wheel could have run a load before coming to a halt, but now both came to a halt and we didn't use the energy!
I hope Rhead managed something. From his latest video's I don't se what his plan exactly is.
Reguarding your 2 wheel brain teaser:
The two wheels will as a whole stop rotating, but for a sure, the energy won't just stop... It will be fully converted into multi frequency vibrations down to the molecular level, resulting in heat, sound and possibly damage to the wheels. The same thing that happens to airplane wheels when they suddenly hit the runway on landing.
Cloxxki
Quote from: MoRo on May 23, 2010, 11:44:37 AM
Good answer :-)
andrea
Quote from: tagor on May 23, 2010, 08:36:30 AM
Why don't you publish your experiments?
tagor
Quote from: andrea on May 24, 2010, 04:00:28 AM
I put severals pics of my setup here
the losses are very small , there is no heat
the input is very week , it is a solar panel 4 cm x 1 cm !
I have with the same input a simple pendulum and a double pendulum
when then simple one runs the double one does not
but when the double one runs it has more speed and more apparent energy
but when you load it , no more energy
dont try mecanical load because all the losses kill the effect
