Merg
The latest update from veljkomilkovic.com
New Breakthrough in Over Unity Theory
Dear friends,
we are glad to inform you that a new breakthrough has been achieved in over unity theory!
After the research and analytical work a new theory has been developed and now Jovan Marjanovic and academician Veljko Milkovic are presenting the theory which says that acting force against moving body will not only accelerate the mass of the body, but also its initial kinetic energy too. The product of initial velocity and additional velocity times the mass would be measurement of extra energy or over-unity energy...
Jovan Marjanovic & Veljko Milkovic - Kinetic Energy and Over Unity
The goal of this work is to point out some important facts in formulas for kinetic energy and momentum (quantity of the movement) for moving bodies.
It will be shown that over unity behavior is inherent in movement itself.
In this work the authors will discuss:
- origin of the formulas for linear momentum and kinetic energy,
- principle of adding energy to a moving body as the key for over unity,
- initial velocity in gravitation field,
- the best way of adding energy to the pendulum,
- validity of relativity of classic mechanics inside an inertial frame.
Key words: velocity, kinetic energy, momentum, over-unity, pendulum.
The complete paper can be read on the next link (PDF - 155KB):
http://www.veljkomilkovic.com/Docs/Jovan_Marjanovic_Veljko_Milkovic_Kinetic_Energy_and_Overunity.pdf
exnihiloest
Quote from: Merg on June 10, 2010, 08:49:14 PM
As proof of OU, it is stated that:
- when you push a ball with a certain work and a force F, it acquires a velocity v, and a kinetic energy 1/2*m*v²
- now the ball is rolling, and you repeat the first operation: you push again the ball with same work and same force F, it acquires a velocity 2*v, and a kinetic energy 1/2*m*2²*v²
It is concluded that:
we have only doubled the work and obtained four times the kinetic energy!
This is total nonsense. Speed is relative to a reference frame, and so is the kinetic energy.
Energy is frame dependant.
In order to suppose that the work to accelerate the ball from 0 to v is the same as to accelerate it from v to 2*v, we have to suppose that in the second case, we accelerate the ball from 0 to v in a reference frame already at speed v relative to the first one. Thus we calculated two works of same value but relative to two different frames of reference. To add them is meaningless.
From the initial reference frame, we accelerated the ball from 0 to 2*v, therefore the work we expended is of cource 1/2*m*2²*v².
The way Marjanovic does physics math is an absurdity not only from relativity viewpoint but also in Newton's mechanics.
Merg
The latest update from the authors:
Dear Friends,
Several people already expressed great concern about possibility if the force acting against the ball could pass the same energy to the ball after the ball started to move.
The problem was that the force should pass extra path in order to catch and push the ball.
We already explained that the force must be fast enough in order to catch and to push the ball.
However, we forget to mention that acting force should be an Impulse, without passing extra path.
Imagine turning the wheel by the hand. The hand would pass the same path every time, but probably somewhat faster next time. Magnetic force would be the best to use. If acted on the wheel it would act against nearest magnet on the wheel and pass the same path every time.
By using the pendulum all this issues would become invalid because the pendulum comes to stop on each side and there is no any extra path passed by the force if the force was used in highest positions.
To illustrate impact of extra velocity (this time it was angular velocity) to the space module Explorer I, please read the document on the internet:
„Von Braun’s 50-year-old Secret“ on the site:
http://www.enterprisemission.com/Von_Braun.htm
Sincerely,
Jovan Marjanovic and Veljko Milkovic
exnihiloest
Meaningless. What means "fast enough"? How much? What means "passing extra path"? Where is the impulse applied from? Where are the equations? Those in the pdf are wrong or misinterpreted. It has to be honestly rewritten.
Milkovic's pendulum is a usefull device for some applications but under unity and perfectly explainable with current known physics laws. Nothing more. Or prove it by making it selfrunning instead of providing misleading math; this work would be much more profitable. If we had "12 times more output than input", this should be very very easy...
