0 Members and 25 Guests are viewing this topic.
Merg
COPIED FROM "Closing the loop on Milkovic's two-stage mechanical oscillator?"
http://www.overunity.com/index.php?topic=7443.msg
QUOTE FROM AnandAadhar
Well, nobody... Studying the pendulum to drive a flywheel, I've also studied the two-phase pendulum of Milkovic, and looped the two phase pendulum succesfully with a flywheel and a feedback magnet pulsing back the pendulum, but it gave no overunity in my set-up. It works indeed as he demonstrates, the pendulum being pushed can drive a wheel or a pump. But claiming overunity here is a bridge too far to my opinion. Milkovic inertial oscillator is inspiring though. The principle works best if you create a disc with a weight positioned on one side and then vibrate the axis in a linear fashion. That easily gives a turning rotor. Thus it is suited for converting a linear movement into a cyclic one. Inertial oscillation is a principle used by Finsrud also in His perpetuum mobile. His ball is the weight oscillating the central pendulum in his machine. So there is a connection with PM and OU. But gravity (like magnetism) alone is conservative and will not deliver energy without engaging magnetism actively with this gavitational oscillator e.g..   That is my conclusion as yet.
My Milkovic replication Video: http://www.youtube.com/watch?v=HJsXLiLNJHA
My Finsrud analysis: http://www.youtube.com/watch?v=E9GucVwc36Q
AnandAadhar
Quote from: Merg on July 18, 2010, 12:37:52 PM
Okay
Anand Aadhar free energy research pages: http://theorderoftime.com/science/free_energy/index.html
Merg
@AnandAadhar
you should read these two papers published by Milkovic team on attempts to mechanically close the loop
Mechanical Feedback Loop Problems and Possible Solutions for the Two-Stage Oscillator of Veljko Milkovic
http://www.veljkomilkovic.com/Images/Jovan_Marjanovic_Mechanical_Feedback_Loop.pdf
Keys of Understanding Gravity Machines of Veljko Milkovic
http://www.veljkomilkovic.com/Images/Jovan_Marjanovic_Key_of_Gravity_Machines.pdf
AnandAadhar
Quote from: Merg on July 18, 2010, 01:37:10 PM
@AnandAadhar
In fact I tried the first Marjanovic suggestion of using a disc with a weight at one side. I made it into a loop. No overunity has been observed with what I tried.
video:
http://www.youtube.com/watch?v=lYAKzW0H2yY
Merg
I have collected the posts related to Milkovic's oscillator from other topics
http://www.overunity.com/index.php?topic=9410.0
From Ted Ewert
I am not implying that a rotating pendulum is incapable of producing extra energy. Milkovic has shown how his oscillator generates energy from a pendulum. The problem is that the Chalkalis device will not produce any extra energy on the main shaft as it has been presented.
You'll see this for yourself if you build a replica. Then you can figure out a real way of extracting energy from this device.
Cheers,
Ted
From Cloxxki
Milkovic has shown nothing, other than a nice way to get high torque out for short pulses, from longer low-torque, equal work input. Not one replication, even a recent genious one that had full syncronization from output to input, ( http://www.youtube.com/watch?v=HJsXLiLNJHA ) was unable to keep going, let alone offer the 12x claimed output.
If you've ever seen a better attempt, let alone by Milkovic himself, please let me know, I'd be most interested to see, study, and replicate it.
From Ted Ewert
That was indeed an elaborate and clever attempt to loop a pendulum, but I could have told you it wasn't going to work. I've tried the same thing only to find that the timing of the pulse is critical. If the feedback pulse is applied at the wrong time it won't work no matter what you do. The Milkovic device is also primarily an oscillator, which denotes resonance. This attempt never got anywhere near resonance, which in itself invalidates any conclusions.
Not being able to loop the output power only proves that the method used was unsuccessful. It does not prove anything else. The attempt cited here merely shows me that this guy didn't really understand the primary mechanism to begin with.
From Cloxxki
I think your response doesn't do the attempt justice. I, for one, don't believe or at least don't understand the hype about resonances. I've yet to find a situation where 1+1=3.
Would you like to venture that a similarly looped system will prove to be a source of energy when merely timed a bit better? This would imply that indeed timing of an input pulse is vital. And that then would imply that energy is lost or won, depending on timing of release. Such a statement would be going against preservation of energy.
Anyway, what do I know. So many geniouses are devoting their free time to Milkovic, and all we get is odd oscillations, always under unity.
From Ted Ewert
The guy who built that feedback mechanism didn't understand how the Milkovic oscillator really works. It's as simple as that. The impulse should be applied at the top of the stroke, not at the bottom. Also, if you have too much vertical travel, like this guy did, it takes all the velocity out of the pendulum. There is also a delicate balance between the pendulum weight, it's period, the length of the lever and the weight or springs used. He was dead in the water before he started.
Until you build a Milkovic replication and get it into resonance, you are just fooling around with a very inefficient pendulum.
Milkovic calls it an oscillator for the simple reason that it doesn't work worth beans until it is oscillating (in resonance).
Very few people take the time and effort to really understand what's going on with his device, which is well worth replication and study.
Ted
http://www.overunity.com/index.php?topic=7443.15
From Xaverius
Closing the loop on this device should be simple in principle. You could use a solenoid plunger or pulse motor rotation.  Have you checked the results of Raymond Heade's work in the Dallas Texas area?  He was supposed to have built a large outdoor device with an attachment to close the loop in October of 2009.  I haven't kept up with it lately, you might write Raymond, he's easy to talk to and his input is in these forums.
