AnandAadhar
Quote from: exnihiloest on September 30, 2010, 03:06:55 AM
If there is OU in Milkovic's pendulum (which is far from being proved), where the energy comes from?
If we accept the hazy hypothesis that gravity is the source, then what is depleted in gravity? From Newton's equation, g= G*M/d² where at the earth surface, M is the earth mass and d its radius. Does the earth mass would decrease each time a Milkovic's pendulum does work?!
Of course not. if that happens the acceleration is taken out of gravity. According Einstein's theory of gravity, gravity equals the acceleration of a rocket. It is called the equivalence principle. So what happens is that with production of OU energy this way, gravity is consumed. The machine will float like a flying saucer if the process is upgraded. Good huh? But that's not Newton anymore of course.
For you can also think of gravity in quantum mechanical terms, as a stream of gravitons or 'space particles', or quantum foam bubbles, rushing towards the planetary center. Gravity as a form of spacetime pressure. Such an experimental finding would prove quantum gravity and give us time travel! A unit of space equates to the duality of universal time expanding and time contracting according to other modern ether theories.... Time is thus addressed too, not just gravity. Man, we would have warp drive in a decade if that experiment succeeds (leaving the Milkovic' version of the machine at home of course for being a primitive precursor in proving the apparently missing laws of the energy of time and gravity in Maxwell's equations).
Anand Aadhar free energy research pages: http://theorderoftime.com/science/free_energy/index.html
AnandAadhar
Quote from: tagor on October 03, 2010, 02:31:46 AM
look at this video
http://www.youtube.com/watch?v=x7Yd71fzlB4&feature=related
this is a double pendulum , but no OU
That's a remarkable study. The way it sustains its action without having had a real push. Just the fall from its loaded position.
Merg
preparation for making a pendulum pump?
http://www.youtube.com/watch?v=Vd__X6-NVCg
"tsmo ver.4.1 working on adding flywheels to replace springs next then new air /water pump. Still experimenting with pendulum weight and length, lever ratio, and spring placements. present water pump is made from allthread(shaft), fender washers(piston), pvc body, and 4 chk valves.Does not wok to well, 6 to 9 liters per min. I need a better construction ---working on simple diapragh pump."
