0 Members and 25 Guests are viewing this topic.
andrea
Quote from: mdlarouche on December 30, 2010, 10:46:15 PM
I looked at things a little different and thought that since a pendulum ultimately comes to a stop why try to keep it in motion permanently because in reality trying to impart the energy necessary to do that is rather difficult because if you try to connect something to do that then your pendulum is not simply a pendulum anymore, and by adding energy either directly or by striking something to input the necessary energy you have a situation where there are parasitic losses and unwanted vibrations. What I have done is stop the pendulum after one single back and forth stroke at the highest position it has reached minus the loss to friction during that stroke. Since the pendulum is the single most efficient machine that exists... All I have to do now is compensate for the losses to friction and force the stopped pendulum up to it's initial start position... Much like Milkovic does by pushing the pendulum with his hand to compensate for those losses. There is a feedback mechanism I have designed to do this and at this point I can't tell you this part. The other thing that I have done is make use of hydraulics to transfer the output of energy to another area that is necessary to keep the timing of things.
I too think that the realization of a feedback mechanism for maintaining the pendulum moving is the real problem of the Milkovic's system. You could think to use an electric motor applied to the bearing of the pendulum, and to apply mechanical or electronics sensors to activate it in the proper instant, ok. But what kind of motor, when it's in the "passive phase", moves itself with no friction? With no friction in both the directions, clockwise and anticlockwise. No one, as I know. Maybe someone have an answer? Otherwise we could think to solve the problem with an air compressed pump, but you have the same problem in the "passive phase".
..buon 2011 a tutti :)
Merg
latest from veljkomilkovic.com:
Veljko Milkovic -- Leonardo da Vinci Gravity Machine
Old story is passed on from a generation to the generation that Leonardo’s gravity machine amazingly worked, but original model wasn’t saved, only drafts we can find on internet or in rare books...
...to ask question if greatest minds like Leonardo da Vinci (1452-1519) were in total delusion or at least something different is still possible?
The complete paper can be read on the next link (PDF - 571KB):
http://www.veljkomilkovic.com/Docs/Veljko_Milkovic_Leonardo_da_Vinci_Gravity_Machine.pdf
Machi
However, exceptions are everywhere around us!
Exceptions for the first law of thermodynamics are forbidden!
Dual mechanical oscillation system by Milkovic Veljko is the same!!! Real OVER UNITY
tagor
Quote from: Machi on January 30, 2011, 11:25:52 AM
sorry but this is NOT REAL
