Merg
...YouTube babarlizia update:
Milkovic replication, first step
http://www.youtube.com/watch?v=DaRm_8R3y0k
I'm trying to build a working system. For now, the greater problem is to maintain the pendulum's oscillation until a useful elevation. The piston works with ten atmospheres.. too much, bad efficiency. Sorry for the bad quality of the video (photocamera) and for the bad English speaking :)
Merg
...related video:
Magnetic Electric Generator
http://www.youtube.com/watch?v=sivnp3VhcYY
Swinging pendulums generate electricity.
Merg
Milkovic replication, second frame
http://www.youtube.com/watch?v=SpOMUZ8fj58
Same configuration. On the longer arm of the system is applied a generator (12V cc) with the proper lamp.
Solomon111
Quote from: Merg on May 29, 2011, 06:26:34 PM
The experiment is the measure of everything. Only in this way should be continued. The more evidence that this is the right thing.
Merg
...from veljkomilkovic.com e-newsletter:
Branisalv Serdar, M.Sc. in Mechanical Engineering, has conducted his own research and expertise of Veljko Milkovic's elastic string pendulum experiment:
Branislav Serdar -- Analysis of movement of a system with elastic pendulum
This paper analyzes the sliding friction and the rolling friction of a moving system, driven by oscillations of the pendulum with an elastic pendulum handle, which was mounted on the system.
The aim was to observe differences in the systems under the effect of impact forces (from plastic and steel calipers) on the metal ball, as well as to analyze and compare the results obtained.
The complete paper can be read on the next link (PDF - 457KB):
http://www.veljkomilkovic.com/Docs/Branislav_Serdar_Analysis_of_Movement_of_Elastic_Pendulum.pdf
accompanying video: http://www.youtube.com/watch?v=O1hvIoNn6I8
More info:
http://www.veljkomilkovic.com/OscilacijeEng.html
