gdez
@ Neptune,
I am making no apologies and don't intend to. I was talking about producing energy, putting people to work and making a profit. Gravity is a never ending force that is all around you and and it just seems to me that it's how you utilize it. Nothing different then combustion, wind , tide or solar. Good luck with your build Neptune. For everybody else, build it or stop blabbing. My hat is off to all the people that I see building things. You just don't know till you try it.
fishman
Quote from: neptune on December 21, 2011, 10:24:40 AM
I started work on a small model today .
Don't go to small. The ratios of input to "output" go up drastically as the size (COG of bob to pivot point. or length of pend arm) and mass increases.
neptune
@Fishman . Yes , I suspected that size matters ! My current model will use a pendulum about half a meter long . I f I can prove OU  to myself , no matter how small , I shall be inspired to build the next one bigger .
johnny874
   Hey Guys,
Y'all want something to think about when it comes to smot's ?
Check this out. It seems he figured out a way to control the magnetic field.
If you put a north pole magnet on a bob, then when it swings by, it should get the same push. Then set up the magnet to switch directions for the swing back to start.
It works for his magnetic motor, should work for other things.
The bright side to all this ? Well, if you can get a pendulum swinging constntly by using what krudelta found, it might help to make Vjelko's pumps free energy pumps.
Up to you guys though. Have my own project. Until then, I think i will be 10 10 on the side.
http://www.youtube.com/watch?v=cGq2WSnE7j0
neptune
Hi Guys . Making some progress on my test rig . I have a base board with 2 stanchions , and a see-saw lever mounted on an old bicycle hub . Built on a zero budget , it will win no prizes for woodwork , but it is functional which is what matters . !00% recycled materials .I have also cast some test weights from ready mixed concrete which I begged from a local building site .They should have set by boxing day .
       Whilst working on this , a theory keeps coming into my head . According to the mathematic analysis of the 2SO by Jovan Marjanovic , The overunity comes from centrifugal force . So it might be possible that we could harvest energy from centrifugal force without involving gravity . Imagine 2 bike chainwheels [front sprockets ] mounted on a beam .The beam is like a see saw mounted on its side with the axle vertical . The 2 wheels are mounted , one each end of the see saw , also on vertical axles . A chain links the 2 wheels so they turn together in the same direction .Each wheel has a heavy weight mounted on its rim . We will view the device from above . At the start the weight on the left wheel is at 12 oclock , and the weight on the right wheel is at 6 oclock . We now turn the wheels 90 degrees clockwise so on the left wheel the weight is at 3 oclock , and on the right wheel 9 oclock . The centrifugal forces on the 2 weights cancel each other at this point . After a further 90 degrees , the left weight is at 6 oclock and the right weight at12 oclock . The centrifugal force on both weights acts to turn the see saw anti clockwise . After a further 90 degrees the left weight is at 9 oclock and the right weight at3 oclock . The forces cancel . The final 90 degrees takes the left weight to12 oclock and the left weight to 6 0clock . the forces combine now to turn the seesaw clockwise . So as the wheels turn the seesaw oscillates back and forth . We need to limit its movement to a small arc . Two poblems arise . How do we drive the wheels as it oscillates , and is it OU ?.The oscillating see saw can be linked to a crankshaft , which is linked somehow to the rotating chain wheels to ensure synchronisation .A diagram will help you visualise it .
