norman6538
In the following video each swing down of the pendulum makes the other end lift up so
I take it this is inertia doing the lifting. I thought leverage would play a role but it seems
not.
http://www.youtube.com/watch?v=IOYveBn3ibE
therefore the physics forces should be easy to calculate.
And notice that he changed the fulcrum/leverage and was able to get it out of
sync such that each swing did not lift the other end. So my thinking is that the leverage allows the oscillation but is not the real lifting force.
Norman
norman6538
another configuration
this guy gets a large down pull on the swing out but not on swing back and none at the bottom
at about 1 min or so  leverage is about 1:1
http://www.youtube.com/watch?v=Y1cKWIAFT0I
Norman
List
In the year 1903, the first plane was made by brothers Wright. Their first successful flight lasted 12 seconds and crossed the distance of just 40 m. After this, the aviation industry flourished. The point is that all pioneer works are hard and have similar flow of the story. Therefore, I consider this experiment http://www.youtube.com/watch?v=yLV33t63CqY  as a really good start and I hope that this idea will develop!
List
Merg, thank you for sharing paper about two-stage oscillator published in Asian Journal of Science and Technology.
http://journalajst.com/sites/default/files/Download%201339.pdf
It is evident that overunity is complete, proven by measures and calculations. Also they made a solid model and tested everything. Although, some technical improvements to the model are possible (in e.g. better size ratios and use of other materials).
zoelra
You all might want to check out the link and read the comments related to the study showing OU.  I believe there is some doubt as to its validity.
http://www.pureenergyblog.com/2013/08/28/1761/8502373_another-academic-paper-concluding-overunity-in-the-milkovic-two-stage-oscillator/
I have built several 2SOs in the last few years, 360 degree versions and original Milkovic versions, and none came close to OU.  My guess at this time is they are at best break-even devices (excluding friction and air resistance).  I continue to work with them, and hope to some day prove myself wrong.
