0 Members and 67 Guests are viewing this topic.
arbus
Hi, i am not a scientist. Just an engineer. I was reading the posts here and decided to try this experiment.
Here's what i found.
The oscilation effect caused by the pendulum is caused by the weight of the pendulum bending the spring(in the simple example).  This energy is transfered from the pendulum to the spring.
This is similar to when you are on a swing. You move your legs out and in and the energy is transfred to the swing.(ok its reverse, but same principle. Your legs are oscilating)
If you make a simple pendulum on a spring wire you can oscilate the wire and make the pendulum go back and forth. ie reverse the process using the energy of the oscilation and the stored energy of the spring.
The trick in the viedos where he is banging the hammer is that he has a BIG HEAVY pendulum and the energy is being stored in the pendulum stroke and cracked down using energy transferance.  He is putting in alot of energy to push the pendulum as it is losing energy fast!
Think of it this way. 1 person can push a car and if that car hits you even slowly it can crush you. But if the person was simply pushing you directly you wouldnt be hurt.
with a heavy pendulum you could bruise your finger near the high point of travel if you got it stuck between the pendulum and something hard.
The picture of the poor Africans pushing a pendulum to pump water isnt new. THe energy is being stored and released. The pushing of the pendulum takes lots of energy!
If you put 2 identical pendulums next to each other, one swinging on a spring the one on the spring will stop first, because it is using energy to oscilate. If you exert oposite force on the spring the pendulum will stop quicker.
A pendulum is very efficent but you cant get more energy  from it then you put in.
Think of this.  In a clock wound by  a spring, you can swing a pendulum for days or weeks.  The clock has lots of moving parts but sooner or later the pendulum must stop.
The claim of 12 times the energy is absolute garbage.
sevich
It really should read:
"when using Milkovic's mechanical device to pump water, the involved individual will save 12 times his/her sweat"
He's confusing the "pressure energy" of a womans high heals being sufficiant to raise her off the ground!
Nevertheles Milkovic should be congradulated for his discovery of "gravity assist" in todays mechanics.
FreeEnergy
"He's confusing the "pressure energy" of a womans high heals being sufficiant to raise her off the ground!"
is the woman at a current momentum like the pendulum? or is she at a dead stop?
bsrinon
I think the key to Milkovic's system is mechanical RESONANCE.  Tesla was obsessed with both mechanical and electrical resonance and was successful in creating excess energy using the resonance principle.  I think most of you have seen the video of the bridge that collapsed because it didn't have proper damping. The cause of its collapse was due to wind that resonated with the bridge! By using resonant frequencies you can split water with very little energy, like what Stan Meyer did.
Here's a link showing a string moving a giant column pendulum using resonance:
http://www.exploratorium.edu/cmp/exhibits/r/resonant_pend.html
It looks like by resonating with the giant pendulum, one can build up a huge potential and kinetic energy by just using little force x distance.
Brian
pese
Even some more links tha shown WAVES and his forces,  Even better to understand when they came in resonance als with here harmanic waves....
Copies 1:1 from my collection (with remaks)
27.12.06
http://www.geocities.com/rolfguthmann/index.html
http://www.zayra.de/soulcom/physicsofphi/PhysicsofPHI.html  phsik
http://www.kettering.edu/~drussell/Demos/superposition/superposition.html  wellen erkl?rt
http://www.glafreniere.com/matter.htm  wellen erkl?rt
http://www.glafreniere.com/sa_electron.htm
The Electron
It can also be considered as one half of an electron. ... Mr. Milo Wolff's static electron and its full lambda core, according to the ...
das zeigt ganz klar , dass wenn wellen (bei dir 3 ! , nicht in harmonie laufen,
FEHL-LEISTUNGEN (Schatten) haben !!
