0 Members and 62 Guests are viewing this topic.
a19grey
@gaby de wilde
I?m going to have to agree with arbus on this one.  When I said that ?we shouldn?t waste our time? I meant that we should move on to other possible OU devices.  I?m as excited by this stuff as anyone else, it?s just that it?s clear to me that this particular device, while novel and interesting, is not an OU device.
However, there is a way to show the actual power input-output.  It would require buying some equipment (and owning a computer)  but it should absolutely answer the question.  Take two dynamos and hook each one up to a voltmeter and an ammeter.  Now, they have voltmeter-ammeters that will go to a hub then through a USB port to plot the values directly on screen.  So, since Voltage * I (current) = Energy take one dynamo and place it under the hammer and take another dynamo and simply hold it to push the pendulum back and forth (like in the flashlight examples).  Set the computer up to plot V*I for both dynamo setups and then take the integral of the two curves. If the integral of the energy expended is 12 times the integral of the energy put in, then the matter has truly been shown.  The thing to be careful of (and why the example with multiple flashlights is flawed)
http://www.micropixel.biz/veljkomilkovic/videos/Veljko_Milkovic_(video-7)_Universal_oscillator-generator.wmv
is to make sure that one doesn?t push so hard that the dynamo stops producing any voltage/current since the end of its range of motion has been reached.  If you look at Milkovic?s hand when performing the example above you will note that indeed the flashlight that he is using to push the pendulum DOES indeed light up, but only for a moment.  You can?t see the flashlight lighting up but really need to look at the light on his hand because flashlights are designed to shine light mostly straight ahead and the camera is at an angle to the direction the flashlight is pointing.  If you also note, the flashlight stops shinning BEFORE Milkovic stops pushing on the pendulum. This is because the handle of the dynamo/flashlight can move only so far and he pushes the handle all the way in and once the handle is all the way in you can use the flashlight to push the pendulum and do work without it lighting up which is the problem that I mentioned earlier.
supersam
the way i see it , since there is plenty of power from the crank shaft of the 21 speed scrap bicycle, used as the fulcrum, in my setup, to keep the pendulum swinging as long as you want it to, i just can't see what the question is?
lol
sam
ps:  happy new year
supersam
hey everyone,
SHIFT THE GEARS IN YOUR MIND AND YOU JUST MIGHT LIKE IT!!!!!
lol
sam
supersam
hey everyone,
all you have to do is keep the pendulum swinging, and everything else takes care of itself!!!! there are no more questions after that!!!!  just try it for yourself!!!  i think you will be amazed!!!!  i know i was.
lol
sam
ps: will i post anything?  NO.
FreeEnergy
supersam post pics/vids if you have achieved over unity. sounds like you did?
